Fog light switch question?
  • Thread starter Thread starter 95ssn95
  • Start date Start date May 10, 2011
95ssn95
53
Missouri
May 10, 2011
  • May 10, 2011
Do I need the light blue and black wires for the factory switch or can I cap them? I am using a 3 position switch for aftermarket fog lights using factory yellow and red/black wiring and on the halo rings using factory red/black wire and grounding negative lead.
The wiring diagram doesn't tell me much about the need of light blue and black other than illuminating the switch??
What should I do?
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
May 10, 2011
  • May 10, 2011
You shouldn't need either of those wires if you're not using the illumination. Go ahead and cap them.
Kurt
HISSIN50
34
129
May 10, 2011
  • May 10, 2011
Just be careful of your polarities with the 3 position switch (it sounds like you might be mixing power and ground). A relay can be used to convert polarity.
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
Electrical Fuse 8, Light Green / Black Wire
  • bleedinggreen
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 26, 2025
bleedinggreen
