Fog lights wont turn on?
Jun 15, 2005
349
so I just bought fog lights for my gt...put them in,hooked the switch up to the grey connector, the only one it would fit, fip the switch and nothing..
the switch didnt light up and the fog lights wont turn on...
Any ideas?
Stupid question, but did you have your headlights on when you tried to turn the fogs on? 94-98 needed the headlights on, it was the New Edge SN95 models that could have the fogs on with just the parking lamps.
YEs start with the basics and check your fuse, your foglight relay, and your foglight cutout relay might be stuck closed(cut out fogs when highbeams are on)
Then get a multi meter and check to make sure you have power and ground.
Some where in this forum "someone will know" But you can change the wires in the fog light switch and they will come on when you have just the parking lights on and they even stay on with the high beams also, I did it and love it!
I already did it....well, I wired it to the vert harness
They will come on whenver I flip the switch
My parking lights dont even have to be on
