for some reason my car idles.....
ok i was expecting my car to not idle at all.....today i wrapped up my h/c/i
ported twisted wedge heads
edelbrock performer rpm
fti cam (rather large)
13* timing
75tb
30's and 80mm pro-m
fuel pressure is 42
every other bolt on there is
there is ZERO tuning done right now, but it idle and drives fine:shrug: theres a couple little quirks that happen but nothing that affects drivability at all. im surprised but happy:D
it sounds absolutely NUTS by the way. all hail the lopy CAM:hail2:
Just a FYI- my car idled great for about two weeks after adding the H/C, but as soon as I started tuning on it with adding timing and fuel the dreaded surge and die syndrom started. I hope you are lucky enough that it doesn't happen to you, but I figured I'd warn you. I've seen this happen to a few others as well.
if i understood you correctly, you only ran into issues once you started to tune it (with on e of the self tuners)?
the thing is i am incredibly broke right now and dont have the money to do any tuning to it so if for now it idles thats fine with me.
When I put that cam in my car it idled like crap. If you think that cam is big, you should see my new one :D
Good to hear its all done. I can't wait to see the results! I did about 300rwhp with that cam, unported TW heads and a tfs street heat manifold. You should eclipse that by a lot! It'll want a 6200-6300 ish shift, possibly higher. I shifted at 6000-6200 with that cam with less head and less manifold.
Bump that timing up to around 18*.
its large considering i almost kept the stock cam:bang:. i dont know what i was thinking:shrug:
I also need gears BAD 2.73's are not gonna cut it with this motor
18* ????why so highhhh
You need 4.10's for this combo. But you had told me you might be spraying so the 4.10's will put you out of your powerband on the spray. I say gear it right and stay n/a.
18* will be the ballpark area for best power. Fyi, I gained 1.5 mph at the track going from 14* to 18* on my old TFS 302 combo. Trust me, you've listened to me this far ;)
No, I tuned it originally with the dizzy and an adjustable FPR and THAT is when my idle problems started. It was at that time that I had to buy the eec tuner to cure the idle. I wish you luck, but I'll be surprised if it doesn't start to act up on you. I don't know the specs but mine is on the small side as 302 cams go and I had issues.
i messed with a few things today...spent a few hours with the car trying to understand all the new parts. My fuel pressure was actually at 45, i guess i had it higher last year to compensate for my stock 19's. It is now down to 40. the lower fp made it run MUCH better.
I have an occasional idle issue....Starting the car when it is cold, yields the idle holdong at like 1500 then dropping down to 750 (normal like it should). BUT, after a hot start it will ocasionally surge, sometimes die. When driving the car, it has not died once when coming to a stop nor does it surge at all. It just happens sometimes after a hot start and takes a few revs to calm down:shrug:.
also, it will not start unless i put my foot on the gas to open the tb a little. Why is that?
i did some beating on it today:D
changed my msd pill from 6k to 7k. I did a 1-2 shift a tick over 6k, i think the mph was around 50 at the top of first:jaw:. 2-3 came in around 80:eek:.
all i can say is the car will not stop pulling from 3k to where i shifted the car, and that is with 2.73's:nono:.
