Help Needed Diagnosing Why My Car Has A Bad Stumble Miss At Wot Only
TwinturboHoward
**Solved** (I think). See post dated 6/13/2017
Hello all, I have been on this site many, many times for solutions to my repair needs, but this problem has me stumped and I could really use the help. I'll try to keep it short...
Short background;
- car is a 1986 fuel injected 5.0 that's been upgraded to 89 electronics.
- engine is a stock rotating assy, including cam - 125,000 miles or so.
- custom twin turbocharged - 42 lbs injectors, re-curved pro-m blow through MAF.
- original TFS street heat heads with new FR5 NGK spark plugs.
- wires are Accel 300+ and have been removed, inspected and measured for resistance - all seems well.
- MSD brand cap and rotor is new from last fall - 500 miles at best.
- MSD blaster coil - 8227, but I do not have the MSD-6AL connected right now.
- fuel pump is an old SX 80 or 90 gal/hour with a new high flow filter and the fuel pressure climbs at WOT as it should.
- Only codes are emission related - 31,81,82,85,84 - not sure why they get provided out of order.
- car has run perfectly fine in the past, but sat for several years, and now I'm trying to get it in good running/driving order.
The car starts, idles and drives just fine. At WOT or heavy acceleration, just as boost is coming on, it stumbles/stutters real bad so I have to release the throttle, and it's back to driving just fine again.
Could this be a bad TFI or PIP? I have never replaced these items since I bought the car back in 1988.
Thanks in advance for any help,
Howard
What's your plug gap - should be .032-.035 with pressurized induction.
High speed miss on a warm engine
Revised 7 Nov-2016 to add PIP sensor as possible problem and dumping the codes to help determine if it is the TFI or PIP.
The TFI module mounted on the distributor is one of the culprits for a high speed miss on a warm engine. The other suspect is the PIP sensor inside the distributor. If the problem does not occur when the engine is cold, the TFI module or PIP is definitely suspect. Dumping the codes may help determine which one it is. You may need a special socket to remove the TFI module, but most auto parts stores will have one for $5-$7.
Be sure to use plenty of the heat sink grease on the new TFI and clean the old grease off the distributor.
See Automotive Tools Specialty | Auto Mechanic & Technician Diagnostic, Testing Equipment | Thexton
diagram courtesy of Tmoss & Stang&2Birds
Hello Jrichker,
I measured the plug gap at just over 0.035" although the NGK website lists them at 0.039" (1.0mm).
Thank you very much for the TFI test sheet. I will look at those values at the next opportunity to have a "car day".
My next step was to re-install the MSD-6AL, but even if it somehow fixed the issue, the issue shouldn't be there to begin with and I'd like to solve it before moving on.
Gosh, probably about 4 or 5 years ago. One day, about 4 or 5 years ago, I decided to "fix a few things" and that turned into the car being non-driveable for one reason or another. Last fall, I got everything back together and it actually fired up (I was truly surprised). Some new tires and brakes, and it was driving - although it has this heavy load/wot issue.
It sounds to me like you're blowing the spark out. If that's true, that MSD box is not going to help you.
I wouldn't rule out bad wires just yet. They can still leak/arc even though the resistance check is good. You might also want to check coil saturation at the top of the power-band. Voltage could be falling off.
If any of the above is true then it's also possible you're not getting voltage saturation at the fuel pump (another thought that crossed my mind).
What do your plugs look like when you pull them out?
Thanks for the reply Noobz347. I don't know how to check any of those values, but I drove the car on a more extended run, about 50 miles) and it barely made it home. With regular, low speed driving, the last 3 miles or so it progressed from driving fine, to a bit of a stumble, to missing regularly, to stalling from a steady state 1800 RPM's or so. Amazingly, still no codes. I have a distributor that's been in my basement for a long time. I'm not sure if it works, but it's worth a try - i.e. free.
Well, I got some car time on Saturday and I changed the entire distributor to another one that I had on the shelf. Car fired up and drove just fine, until I gave it a heavy load, then stumble, pop, stumble (or something to that effect). No codes, no change from the previous distributor - although I didn't drive it long enough to determine if it did the progressive missing and stalling, like before. I'm assuming it would have.
I'm really stuck now. I'm going to change the coil to another, known good, used one that I had on the car a couple of years ago.
Oh, and I did a late night check for sparks and everything seems dark - no obvious sparking, but that's only in the driveway with no load.
Does it pop at higher rpm, just under load, or both?
Just under load. To make it easier to 'test', I usually put it in 3rd or 4th gear at about 35mph and floor it. In the past, it performed great. Now it starts to pop just as boost starts to come on, which is about 1-2 seconds and about 2500 RPM or so- maybe that's a clue?
I'm thinking either your coil is weak or an A/F ratio not being managed correctly. I'm also wondering if the ignition advance is not working properly.
Well, over the weekend I changed to an old Jacobs Ultra Coil that I had laying around. The car initially seemed better, but it still misfires under load - although I would say that it's not quite as bad - maybe.
I'm with Dart68 on this on. Popping back out the intake is a real problem and it is usually because of a lean mixture.
Backfiring out the intake is either a valve stuck open or a lean mixture or spark plug wire(s) connected to the wrong cylinder(s). Check compression on all cylinders and then look for vacuum hoses loose, cracked, or misconnected. Check the line for the vapor recirculation system – it is easy to knock loose and not see it when you connect the air pump plumbing. If the vacuum line for the EGR valve and the air pump are cross connected, some very strange things can happen. Check the mass air flow electrical connection and see that it is tight, the same goes for the fuel injection wiring harness connectors up on top of the manifold near the firewall.
Sticking valves: If a intake valve is bent, has a bad spring or is misadjusted, the engine will sometimes backfire through the intake. Use a vacuum gauge connected to any convenient spot on the intake manifold. Run the engine at 1000 RPM & look for 18-21 inches of vacuum with a steady needle. A problem intake valve will make the vacuum gauge needle sweep 5-10 inches.
Lean fuel mixture breaks out into several sub categories:
A.). Vacuum leaks
B.) Air entering the intake without passing through the MAF on Mass Air cars (89-95 models).
C.) Failure of the MAF, BAP/MAP (Baro or Manifold Air Pressure, same sensor, different name), ACT (air charge temp), or ECT (engine coolant temp). These should set a code in the computer.
D.) O2 sensor problems: one or both O2 sensors with low output or bad O2 sensor heater ground. This should set codes 41/91. The O2 sensor heater ground is an Orange wire in the engine mounted fuel injector harness. Ground it to the back of the head or intake manifold.
E.) Leaking exhaust gases from EGR valve at WOT or EGR opening when it should not be open.
F.) Poor fuel delivery due to bad fuel pump, clogged filter or bad fuel pump wiring. Look for low pressure or fluctuating pressure. Standard injector pressure is 39 PSI at idle, with the vacuum line disconnected from the regulator and capped.
G.) Clogged fuel injectors.- see the cylinder balance test below
H.) Fuel injector wiring problems causing injector not to deliver rated flow (dirty or stuck shut injectors).
I.) Computer problems: (computer problems are not common like sensor problems)
J.). ROM has bad data in fuel or timing table. This should also set a code in the computer.
K.) Failure of one or more of the computer's driver transistors for the fuel injectors. No code set on this one. Use a noid test light to test the injector wiring & injector drivers,
L.) MAF calibration off or mismatched to injectors.
M.) ACT or ECT bad. Sometimes the sensors will be off calibration, but not bad enough to set a code. If they falsely read too high a temp, the engine will back off fuel delivery.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
Vacuum leak due to slipped lower intake manifold gasket...
Ask Nicoleb3x3 about the intake gasket that slipped out of place and caused idle and vacuum leak problems that could not be seen or found by external examination. I don't care what you spray with, you won't find the leak when it is sucking air from the lifter valley. It simply isn't possible to spray anything in there with the lower manifold bolted in place.
photodisplay.php
Cylinder balance test: use this to find dead or weak cylinders:
Revised 22-Mar-2017 Added disclaimer for the YouTube video that shows how to do a cylinder balance test.
The computer has a cylinder balance test that helps locate cylinders with low power output. You’ll need to dump the codes out of the computer and make sure that you have the A/C off, clutch depressed to the floor and the transmission in neutral. Fail to do this and you can’t do the engine running dump codes test that allows you to do the cylinder balance test.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, have the clutch depressed to the floor, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Here's how to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and drivability problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you dump the codes and then you start the engine with the test jumper in place. Be sure the A/C is off, clutch depressed to the floor and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see www.midwayautosupply.com/Equus-Digital-Ford-Code-Reader/dp/B000EW0KHW Equus - Digital Ford Code Reader 3145.
It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $22-$36.
Order it at Walmart for a better price and free shipping
If you have idle or IAC/IAB problems and the engine will not idle on its own without mechanically adjusting the base idle speed above 625-750 RPM, this test will fail with random cylinders pointed out every time it runs. The IAC/IAB must be capable of controlling the engine speed to run in the 1300-1500 RPM range. Playing with the base idle speed by adjusting it upwards will not work, the computer has to be able to control the engine speed using the IAC/IAB.
Warm the car's engine up to normal operating temperature. With the test jumper in test position, start the engine and let it stabilize. It should flash a 10 and then a 4 and maybe an 11. If no 11, then there are other codes that will be dumped.
One of the first tests it does is to open the EGR all the way, this will cause the engine to stumble and almost die. If the engine dies here then you have EGR problems.
To start the cylinder balance test, briefly floor the accelerator past 2500 RPM and let off the accelerator. The engine will stabilize at about 1300-1450 RPM and the cut off the fuel injectors one at a time. The engine speed will drop briefly and the computer will turn the fuel injector for the cylinder under test back on. Then it starts the process for the next cylinder. When it has sequenced through all 8 injectors, it will flash 9 for everything OK, or the number of the failing cylinder such as 2 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures.
Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
See
View: https://www.youtube.com/watch?v=HDXrkKS4jTE
for a visual tour through the process. There is no voice narration so you have to listen carefully for the engine sounds. I posted the link for the benefit of Stangnet members who had questions about how to do a cylinder balance test. I do not own that video and I am not the creator.
Ok, I think I solved it. Over the course of the year, I've been trying to make the car a bit more enjoyable to drive and remove some of the 'race oriented' types of parts. This weekend, I replaced the very loud SX external fuel pump with an Aeromotive 340L in-tank pump. Now, the pump is almost silent and, even better, it solved the WOT stumble/miss/fall-on-it's-face problem.
It really doesn't make much sense to me because the fuel pressure, never dropped, or wavered in any way. I have a newer Autometer mechanical fuel pressure gauge and a new Autometer braided hose. Maybe the old SX pump was just teetering on the edge of being able to produce the necessary fuel, or maybe the fuel was being aerated somehow.
Either way, it's running great and I really appreciate all of the help everyone was providing.
Thanks, Howard
