LTs will more than likely fail you. I recommend getting to know the people the give inspections. They can hook you up or you can go to one of those shops that you slip $20-40 and they pass you without testing.godsmak53190 said:what do you do come emmisions![]()
Money TalksJesus said:If the state requires ODB testing, I dont think they can "just pass you" without doing the test.
Stangsgrl said:You need to check your states emissions laws. NC will allow you to have L/T's, but you HAVE to have cats. Hence my L/T/Catted midpipe combo. For E testing, they do the obd code check and a visual inspection. I was told as long as I have cats on my car, I will be fine, L/T's or not. As long as I pass the puffer test, and have cats for the visual I should be fine. There are a fair amount of guys and gals around here that run L/T's and dont have a problem with E testing. Again its mostly up to how strict your states laws are regarding the matter.
Best of luck! Ill know how accurate this is come Oct lol.
what kind of condition are your shorties in?pony_vert02 said:My thought exactly as well... I'm getting set of MAC L/T ceramic coated and installed sometime next month...( It's not cheap installing those things ) My shop suggested that I keep my X-pipe and let them cut it to accommodate the L/T's and reinstall the CATS..that way you pass the 'visual' inspection and sniffer..I'm looking at spending $700-750 for this job..
dkshadow said:
JUST INSTALL THEM YOURSELF!!!![]()
