What should I do
PvolkStang
10
Ohio
What should I do with my 1994 mustang gt looking to put either a cold air intake on or under drive pullies it currently has no cats with flowmasters mufflers and no smog pump not sure if that means anything when it comes to those bolt on’s but if anyone can help then please do thank you
Just to do some simple bolt on’s and work my way up from there, just not sure where I should start or if one of those is better for now or if one will give me more power than the other
Underdrive pullies and Chinesium CAIs [both] cause more issues than they resolve. Neither of those are what I would call, "good upgrades" on a street car.
CAIs can mess with air flow and cause drivability issues for virtually [zero] horsepower.
Underdrive pullies are worth a small percentage from an accessory drive that altogether, costs about 12 HP. Cooling, power steering, and alternator outputs are all reduced. Just about every old guy in here has a set holding a door open somewhere or propping up a shelf to make it level.
Reactions: General karthief
I had a set on my 85 GT and could feel a slight difference at the seat of the pants and the 1/4 mile. But the car had rear gears which spins the motor higher and I don't live in a super hot area.
Rear gears. If you're running a stock ratio, changing to 3.55s is a noticeable bump that you'll feel every time you lean on the throttle. It's a little bit more than a simple bolt-on, but money well spent regardless of whether you do it yourself or pay someone to install them.
  • PlusOne
