? for those with Saleen or Saleen blowers.
semperfi510
249
Fremont, CA
? for those with S/C Saleens or Saleen blowers.
I have a 2000 sc saleen and today I see oil on the ground so I open the engine and my bbk intake and filter are soaked. So I look in the tube all the way up to the throttle body there is oil. There is a bit in the Saleen blower where it connects to throttle body. I cleaned most of it out and I am going to try to take the piece of the blower off to see if it is not wet. What could it be. The tube from the valve cover to the bbk air intake pipe was soaked in oil. Could that of been where the oil came from. And is that a big problem? Any info appreciated.
JOhnny :flag:
jstreet0204 said:
Did you check the pcv valve?
Is that the piece that goes from the valve cover to the cold air intake? If so I am putting in a new one and a chicane ripp kit. I heard it is common with Saleens for this to happen. I am changing that out and cleaning it up.
Johnny
Johnny
Yes thats it. It vents gasses built up in the crankcase back into the intake. If it goes bad, it can let oil through also. I would replace it first since it is cheap.
