Ford AOD questions
Would it be ok to use this tranny with just a "frame-rail" tranny cooler, and not the cooler located in the radiator? How big a cooler would I need?
I don't have the original cooler lines since this is a 2.3>5.0 swap, and I don't want to have to find or make them.
Also, if I put this tranny in attached to the engine, how can i do it without help? I would have to put plywood or something on the ground so that the output shaft doesn't scrape
I wouldn't advise using just a frame rail cooler. I'm worried it won't get enough airflow over it to do any good. I believe they are meant to be supplemental to the one in the radiator. Your way better off just running your own lines with 'transmission fluid hose'. Is your radiator for an automatic already? You might get by with just running your lines to a 28k cooler mounted up front if it's not.
As for throwing in the engine and tranny together, I actually like doing it like that. I always had my car on cinder blocks under all 4 tires. Don't forget to put on the e-break! It's possible to do it yourself with a cherry picker and a 'load leveler'. It's 10 times better to have someone there to guide it.
Thanks...maybe you could come up and help :p
I have a load leveler but its from Harbor Freight so it's kind of crappy. I should be alright if I just lube up the screw I guess.
I don't have the car on cinderblocks, I just jacked it up maybe 4 or 5 inches on one side, so I could get under it and unhook the old tranny.
It sits pretty high with no drivetrain in it though...about 4-5 inches of tire to fender clearance, with 245/45/17's :eek:
