imagine that, a haynes manual having the wrong informationMT1083 said:I think the haynes manual is wrong. I have 2 scan tools that list that code as relating to EVAP.
. More like a lack of information tooBill9000 said:does anyone know of a sure way to get a code without a tool, does the odometer thing work?
Roger_4.6_96 said:I had problem with stupid p1443 code. On here it says. After looking at some of the codes here and then the haynes manual. Alot of them are bunk and appear to be the wrong code.
Here. P1443 Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault.
In the haynes manual it says
Haynes. P1443 Idle Air Control (IAC) Valve Speed Fault.
ford's PC/ED book said:P1443 - EVAP Control System Canister Purge Valve (Mechanical) Malfunction Monitors the fuel vapor flow between the engine intake manifold and the EVAP canister. The system failure occurs when a leak or blockage between the intake manifold, the EVAP canister purge valve and the EVAP canister is detected by the PCM. Pinched, blocked or plugged fuel vapor tubes/hoses (except between fuel tank and EVAP canister)
Damaged EVAP canister
Disconnected, cracked or cut fuel vapor tubes/hoses (except between fuel tank and EVAP canister)
Damaged EVAP canister purge valve
Check for audible vacuum noise in the engine compartment or significant fuel odor in the engine compartment or near the EVAP canister.
Roger_4.6_96 said:Actually its a chilton but it says haynes on the first page. So why are the codes different ?
Fred Durst 2KGT said:Anyone know if a P0455 evap. code would be consistent with having an off road h-pipe??
aleborjas said:hi i whant to know if the oxigen sensor are disactivated when you put a chip on the ecu the chip (diablosport) is on a 98' cobra, 42 pounders, supercharger, lightning maff....
other cuestion is did the 98 cobras came with poor spark problems? because in having at 5500 up some poping by the exhaust and looks like missfire and i have stock coils...
