The explorer cam is a mild truck cam.
You go too far from that and you will have valve float.
Basically the springs can't keep up with the cam and could leave a valve very briefly in the wrong position.
With the stock mustang cam i'd guess it could be ok, but at the same time as i said above, why go through the trouble of swapping heads and leaving the stock cam.
With an aftermarket cam, floating the valves eventually is almost certain.
