Heres the tube assembly removal. This one has more pics which probably wouyld help you out a lot. Like I said, if this isnt working for you, let me now if you want me to send a disc or I can try and figure a way to post it in order with the pics.
NOTE: Installation of a new suction accumulator is not required when repairing the refrigerant system except when there is physical evidence of system contamination from a failed A/C compressor or damage to the suction accumulator.
Recover the refrigerant. For additional information, refer to Section 412-00.
Remove the engine cooling fans. For additional information, refer to Section 303-03.
Raise and support vehicle. For additional information, refer to Section 100-02.
Drain the cooling system. For additional information, refer to Section 303-03.
Remove the lower radiator hose, reservoir supply hose, and the radiator lower tube bolt.
Disconnect the following:
A/C pressure switch.
Catalyst monitor sensor.
Push pin from the bracket.
Disconnect the A/C clutch electrical connector.
Lower the vehicle.
Remove the radiator upper tube bolt, and disconnect the radiator vent tube.
Disconnect the upper radiator hose and engine vent hose.
Disconnect the oxygen sensor connector retainer and harness pin-type retainer.
Remove the two bolts, and remove the radiator tube assembly.
Disconnect the compressor manifold and tube assembly peanut fitting from the condenser (19712).
Discard the O-ring seal.
Disconnect the pressure cutoff switch electrical connector.
Lower the vehicle.
Detach the wiring harness.
Loosen the bolt and disconnect the compressor manifold and tube assembly (19D734) from the A/C compressor (19703).
Discard the O-ring seals.
Disconnect the compressor manifold and tube assembly spring lock coupling from the suction accumulator (19C836). For additional information, refer to Section 412-00.
Remove the compressor manifold and tube assembly.
To install, reverse the removal procedure.
Lubricate the refrigerant system with the correct amount of clean PAG oil or equivalent. For additional information, refer to Section 412-00.
Install new O-ring seals lubricated in clean PAG oil.
Fill the engine cooling system. For additional information, refer to Section 303-03.
Evacuate, leak test, and charge the refrigerant system. For additional information, refer to Section 412-00.
