Sorry for the long post.. read if you like
If you dont Please just read the QUESTION at the bottom..
Kwik-Kar lube on Jones road bought me a new tranny about a year ago.. Some dumba$$ didnt put tranny fluid back in..
Joe Myers ford installed it, about 2 weeks later i noticed that it kept getting stuck in reverse.. Hot cold didnt matter, sometime it took some effort to get it out and other time it would get STUCK.. Very random.. Plus the tranny never felt right in the first place.. So i call them and they said they have never heard of that problem.. I started doing research and found a TSB thanks the StangNet about it.. I called Tremec they told me did know about it.. Took it back to Ford, showed them the TSB # "our mechaics know about the TSBs" and after a week they said they couldnt find anything wrong.. i said what about the TSB stating the problem.. "you tranny does not have any problem" i told them to get fooked.. About 3 months later i took it back cause i made a U turn and had to use reverse and got stuck RIGHT in the middle of a 45mph road.. blocking trafic for about 5 min.. It was not fun at all.. SO i took it back PI$$ED, about 3 days later they told me they cant touch it.. " WHY? " you have aftermarket shifter.. (Steeda) I said you install it on my new tranny.. and ford sells it.. So they told me i had to install the stock one and then come back.. A$$holes
So i installed it and tested it my self.. well it still did it.. of course..
I couldnt take off work anymore so i just had to deal with it.. around XMas time I did some more research on the TSB about it.. Went ahead and paid $25 alldata.com to get more than the title for the TSB.. BTW that site is cool found ALOT of great TSB and recalls on my car.. Highly Recommend..
"M/T - T45 Stuck In Reverse/Pops Out Of Reverse
Article No.
01-23-5
11/26/01
TRANSMISSION - T-45 MANUAL TRANSMISSION -
STUCK IN REVERSE - DIFFICULT TO SHIFT INTO
REVERSE - POPS OUT OF REVERSE
FORD:
1996-2001 MUSTANG
ISSUE
Some vehicles equipped with the T45 transmission may exhibit a condition of being stuck in reverse, difficult to shift into reverse or may pop out of reverse. This may be caused by the 5th/Reverse Gear Shift Fork. This article does not apply to the condition of "unable to get into reverse" or "reverse block out".
ACTION
Verify which shift fork is in the transmission, measure the reverse engagement, and replace the shift fork with the proper part number. Refer to the following Service Procedure for details."
There are 3 different shift forks..... Hmmm
"Using the following criteria, select the correct 5th/reverse fork. This fork should replace the current fork in the transmission.
a. If the measurement is less than 68.1158 mm (2.682 inches), use the "long" fork (F8ZZ-7230-EA).
b. If the measurement is greater than 69.233 mm (2.726 inches), use the "short" fork (F8ZZ-7230-DE).
c. If the measurement falls between the above values, then install the "nominal" fork (F6ZZ-7230-C)."
Jan 5 i took it back.. showed them the detailed instutions how to replace the parts.. and told them, Ill measure the forks my self. "No our service men will be fine they know what to do." i said are you sure ? he laughed.. aha
Well they found that 5th/reverse had the wrong fork..
also replaced the synchros too.. OMG NO WAY..
I said you guys are good..
And for some reason they couldnt get it in 1st either.. "remove main shaft and set 1st and 2nd shift gates assemble" ?
Well Feb 4 I get it back and its still doesnt feel right..
doesnt seem to stick in reverse nor is it as noisey but it feels hard going in gears..
QUESTION: has anyone filed a REPAIR REVIEW FORM ?
I just want a new tranny.. im stick of screwing with this.. Plus ive already spent $150 of my SC fund and i want to get it before I blow it all..
Once again sorry for the long post.. It might help some one out there
Matt
I couldnt take off work anymore so i just had to deal with it.. around XMas time I did some more research on the TSB about it.. Went ahead and paid $25 alldata.com to get more than the title for the TSB.. BTW that site is cool found ALOT of great TSB and recalls on my car.. Highly Recommend.. "M/T - T45 Stuck In Reverse/Pops Out Of Reverse
Article No.
01-23-5
11/26/01
FORD:
1996-2001 MUSTANG
ISSUE
ACTION
I said you guys are good.. Well Feb 4 I get it back and its still doesnt feel right..
Matt
.. so i check to make sure they wernt on.. nope..
