Forged internals question
HighMileage said:
I read the crankshaft was lightened, which means weakened. It should outlast the block though?
the crank in the 5.0's is actually the same as every other crank put in the 302 from '87 till the end of production (between '81-'86 they were all the same too, just a different part number). It carries the same part number as all the rest of them. the 2MAE cranks after '80 were all lightened, they have less material in them than the 2M, and 2MA...hence the change in imbalance from 28oz-50oz in '81.
don't worry though, the crank is nodular iron, and the rods are stout units...like 88POSLX said though, you'll split the block before you break anything else
Zero_chance said:
What would be considered safe boost levels to run on a stock bottom end, taking into account a proper tune?
Not so much the boost level as it is the power being made. If you want it to live shoot for 450-500 rwhp. People will say they destroyed motors making less power and others will say they made 100 rwhp more and had their motor live, but on average a 450 rwhp car will last a good while and provide plenty of fun.
