motor is built. no flowbench numbers. i just dont have time for that.
turbo is mounted.
downpipe is welded to the mount.
passenger exhaust to turbo is tacked.
drivers side exhaust is cut to shape waiting for motor install to tack and weld.
wastegate position is finalized. saddle piping will be cut next and welded. waiting for final
installation for welding.
pictures soon.
tou will see in the pics, that i had to make the oiling system. in other words, the plate that attaches to the turbo where the pressure and return lines fit had to be made and tapped.
the standard exhaust housing with 4" v-band and internal wastegate is discarded in favor of a 1/4" thick 304 stainless plate that is drilled to match the turbine housing. a 3" hole was cut for the exhaust piping to weld to.
after a lot of thought, i decided a 'normal' mount using the center housing was not looking tidy. also the position i wanted the turbo to sit is very close to the water pump pulley.
with no frame of reference for mounting it i tried a dozen or so usual placements, and was not satisfied because the turbo compressor housing is so large. 80mm=huge.
it does have the highest flow design compressor wheel garrett makes for this turbo. and in fact it is the 'high flow' option that is sold. it will be noisy at an idle. the whistle will be heard inside others' cars at an idle.
anyway as usual with me everything has to be made. i did compromise in some areas for time. they can be redone later.
1. the 2.5" exhaust is going BELOW the k-member and back through the driver's side in the a-arm area. headers will fix that.
2. i used manifolds. ackkkk!!!! they will go first thing.
3. i used a single 3" exhaust using a dynomax 3"x 26" bullet muffler and one exhaust in front of the driver's side tire.
4. i am using the late gen2 mark viii intake. im going to mod and weld another one i have laying around for better performance. time was the deciding factor.
5. no intercooler installed for a few weeks. the wife isnt going to give up her car much longer, so i'll do it another weekend.
