Four cylinders do not fire
tack_78
87
I just put in my new X2C Motorsports V2.0 shortblock in and now I am having this problem.
Driver's side fires. Passenger side does not. If I pull the CAM position sensor, all eight fire. It does not run perfect but they all fire. I ran a compression test and all eight said 150-155 PSI. I replaced the CAM position sensor. We checked the COPs. All checked good. Checked the injectors. All checked good. Used a NOID light and checked the connectors going to the COPs and the injectors and they all checked fine even with the CAM sensor plugged in. WTF. My next step is to pull the valve covers and put the motor at TDC and see if the two CAM sproketts line up correct. I really do not see how I could have one of them off time but hey. Any of you have any ideas?
