Fox AC problem
  • Thread starter Thread starter joem71
  • Start date Start date Dec 15, 2012
J
joem71
  • Dec 15, 2012
I tried adding the r134 freon from the auto parts store kit into my 90 gt that has the original r12 set up. I've done this before with success in my last car. It pins the needle on the gauge, and won't kick on the AC clutch. Even tried jumping out the relay. Still no luck. Is it the compressor, clutch, or ?
TOOLOW91
20+ Year Stangneter
8,761
234
S.I.NY
Dec 16, 2012
  • Dec 16, 2012
well if the clutch isn't kicking in then it's possibly the clutch and it's gonna pin the needle until the compressor runs to stabilize the high and Low sides to where they should be
TOOLOW91
20+ Year Stangneter
8,761
234
S.I.NY
Dec 16, 2012
  • Dec 16, 2012
you should be able to apply 12 v right to the clutch making up a jumper with the car running and you will then know what's up with the compressor , once you do that then get a meter and sort the clutch issue out
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Dec 16, 2012
  • Dec 16, 2012
You my friend, are playing with fire. You may very well have seized the compressor. Fox A/C compressors were NEVER INTENDED to pump r134. They will do it if properly converted but even then, the system is only filled to 80% capacity in order to keep the compressor from bursting.
Additionally, the lubricant used in an r12 system and the lubricant used in an r134 system are INCOMPATIBLE. When mixed, they combine to become VOLTRON... ok, not really, but they DO combine into a gel and make all kinds of problems including clogging every orifice in the system and destroying everything else.
If you have in fact, mixed these two systems, then you're likely looking at a compressor and condenser replacement. The only way to know for sure is to take it someplace that can properly vac the system completely down. The lubricants have to be flushed and totally removed from the system then replaced with a lubricant compatible with r134. Once complete, the system can be serviced to 80% capacity (this is because the expansion rates between the two refrigerants are completely different). If the system still works, GREAT! If not, you're going to be replacing components and lines to get it back up and running again.
jrichker has a writeup or two on the entire process. When I converted mine, I read through the instructions then took it to a shop to have it converted.
Good Luck
Reactions: 65ShelbyClone
J
joem71
  • Dec 16, 2012
The stuff that I tried using, was a conversion kit from auto zone that has freon that is supposed to work. A buddy of mine used it in his 93, and was fine.
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Dec 16, 2012
  • Dec 16, 2012
Not to be contrary but I have a buddy that was born with only one testicle. It didn't create for me, a warm fuzzy about getting rid of one of mine.
Even if you're putting r134 and oil that is compatible with the r12 stuff, it still needs to be done with a proper set of gauges and serviced 20% lower than capacity to keep from damaging the compressor. What is your current A/C, static system pressure?
J
joem71
  • Dec 16, 2012
I don't have a gauge to ck it.
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Dec 16, 2012
  • Dec 16, 2012
Here's my suggestion then. Go to a Meineke or whatever place you have near you. Have the system sucked all the way down. Recharge with the appropriate oil and serviced with R134. They can also check out your A/C pressure switch to ensure it's operating correctly and let you know if you have any external leaks that are preventing the system from holding proper pressure.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Dec 16, 2012
  • Dec 16, 2012
Aside from what was already mentioned, your system doesn't have the barrier hoses and seals necessary to keep 134a from dissipating right through the rubber. That means you will have to top off the system periodically and 134a has a nasty global warming potential, so it's not good to be releasing it anyway.
I have a DIY vacuum pump and an inexpensive manifold gauge set I use for this kind of thing. R134a really should be charged by pressure rather than stuffing 80% of the R12 weight in and calling it good.
Mustang5L5
Mod Dude
Feb 18, 2001
43,361
18,107
224
Massachusetts
Dec 16, 2012
#10
  • Dec 16, 2012
  • #10
But that costs money!! Why do that when I can just shoot a can of r-134a in and call it a day.
(Sarcasm off)
I kinda wish the EPA609 cert would include 134a these days. Buying these cheap conversion kits or dumping 134a into an r-12 system is just not the way.
I actually gathered up the parts to reinstall ac in my car, but using r-12. The idea of putting in 134 in a system not designed for it just doesn't sit we'll for me
Sent from my iPhone 4S using Tapatalk
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 16, 2012
#11
  • Dec 16, 2012
  • #11
Here's what ya gotta do...
R134a Air Conditioner Conversion and recharge instructions
Revised 23-June-2012 to include green R134 compatible O rings used for O ring replacement and R12 charge instructions
Color Legend:
R134 specific items and instructions are in red text
Freeze 12 specific items instructions are in indigo text
Note: R12 is available on eBay. Use the Freeze 12 instructions except use the R12 36 oz refrigerant charge with R12 refrigerant
Items and instructions common to both R134 and Freeze 12 are in black text
Tools and materials you will need:
Gauge set for recharging = $20-$120 – check out the pawn shops for a bargain before you pay retail.
See Harbor Freight Tools for an inexpensive gauge set.
Vacuum pump – I use an old refrigerator compressor = $20- $40 at used appliance stores, or go to the Dump and get one for free. Be sure to have some R12 compatible oil handy to keep it lubed up properly.
O ring seal kit = $8.
Replacement accumulator/dryer assembly with hose $55-$75
Alternative refrigerant – Freeze 12 – it will allow you to skip flushing the system and reuse the original accumulator/dryer under certain conditions:
1.) If the A/C system has not been open to air for more than an hour or so.
2.) Or if it hasn’t out of refrigerant for more than 5-7 days and the system is till sealed up with no open or disconnected lines.
If either of the above is not true, you must replace the accumulator/dryer assembly.
Freeze 12 refrigerant: $15-$16 per 12 Oz can on eBay. Get 3 cans, 2 for the initial charge and 1 spare for a top off charge.
Use R12 compatible mineral oil, 6-8 Oz. This may be difficult to find or expensive (~$20 a quart)
Do not use PAG oil in a Freeze 12 system without flushing it first.
Freeze 12 refrigerant charge= 26-28 Oz plus 6-8 Oz R12 mineral oil on an empty system. A recharge may only require 2-4 OZ of R12 mineral oil if you only replaced a line, hose or seals.
A/C systems that have had a compressor failure must be flushed. Failure to do so will result in the floating trash left behind from the compressor failure destroying the replacement compressor.
R134a = $11-$16 a can – takes 2 cans.
R134a PAG or Ester compatible oil = $7-$12 for an 8 oz bottle .
Pump to force cleaning fluid through the system $20-$50 (may use compressed air to do the same thing).
R134a charging adapter = $13 (I cut mine up to use it with the R12 gauge set that I have had for a long time).
Plastic tools to disconnect refrigerant lines - 1/2" & 5/8" = $4 each.
Flushing agent - Discount Auto Parts has some flushing solvent in a 1 gallon plastic bottle - try that first. Or use Mineral spirits = $4-$5 a gallon, tetrachloroethylene =$5-$10 a gallon, takes 2 gallons of either one.
Miscellaneous hoses and fittings to adapt the flushing pump to the system, and the R134a adapter to the R12 gauge set = $15.
R134 Refrigerant charge is 26-28 Oz plus 6-8 Oz of PAG 100 oil.
R134 Conversion Instructions:
I did a R134a conversion on my 89GT, and used all stock parts. You will need to replace the dryer/receiver (about $75 if you get the one with the hose made as part of the unit), and should replace all of the rubber "O" ring seals as well. You will need to drain all of the oil out of the compressor and replace it with new R134a compatible oil.
R134 instructions (skip this if you use Freeze 12)
Keep in mind that to fulfill the requirements of the EPA, you are required by law to recover any refrigerant that still remains in the system. How (or wither or not) you accomplish this is up to you. Connect the charging gauge hoses to the service ports on the A/C (red gauge = high pressure, blue gauge = low pressure) and open the valves on the gauges to dump the remaining refrigerant (if any) into your "freon recovery system", whatever it may be. Disconnect the charging gauges since you are finished with them until you are ready to fill the system with R134a. Next comes the nasty part – in order to get all the old oil out of the system, you will need to flush it with special flushing solvent, or mineral spirits (ok) or tetrachloroethylene (better, but may be hard to get). If you leave the old oil in place it will congeal and reduce the heat transfer in the condenser and evaporator (read that it won’t cool good) and possibly damage the compressor.
Disconnect the compressor and remove it from its mount to flush it with cleaning solvent. Pour about a cup of solvent into the suction port and turn the compressor center hub about 10 turns while shaking the compressor to move the solvent around inside the compressor sump. Drain the flushing solvent out and continue to turn the center hub by hand to force out any remaining solvent. Then fill it with oil: add about 6-8 oz of the new oil to the compressor large suction fitting. Turn the compressor center hub about 20 turns as you turn the compressor face up and face down to distribute the new oil inside the compressor. Catch and replace any oil that comes out of the compressor.
Connect the pump (I had an electric sump pump I bought for $20) to the hose from the high-pressure side of the compressor. Alternately, you could use compressed air to force the cleaning fluid through the system. I didn’t like to do this since compressed air has lots of moisture in it, which is death to A/C systems. Pump the cleaning fluid through the system and let it come out the hose that was attached to the old dryer/receiver. I used 2 gallons of mineral spirits and pumped it all through the condenser and evaporator. The expansion valve is located near the firewall in the high-pressure line of the evaporator, and may cause the cleaning fluid to trickle through the lines at a very slow pace. You may want to pump cleaning fluid through the evaporator and condenser separately to speed up the process.
Both R134, Freeze 12 & R12
Next comes the changing of all the old "O" rings so that the chances for leaks is minimized. The new R134 compatible O rings are green colored, so be sure that the replacement O rings are green. Use the plastic connector tools to separate the lines, place the extended collar part of the tool so that it faces the large part of the connector and push inwards: this expands the spring so that you can pull the tube apart. You may need a helper to push on the tool while you pull on the tubes to separate them. Install the new "O" rings: be sure to coat them with new oil when you put them in. Install the new dryer/receiver, refrigerant service port adapter on the compressor, add about more 4oz of oil to high pressure line and tighten up all the lines. Close the hood, start the engine, let everything get warm under the hood, but don’t add the refrigerant or turn the A/C on. Connect the charging gauge hoses to the service ports on the A/C (red gauge = high pressure, blue gauge = low pressure) and open both valves, then connect the center hose to the vacuum pump. The purpose of this exercise is to heat up the system so that when you vacuum it all down (yes, you will need a vacuum pump- mine is an old refrigerator compressor), that all the air, vapor and moisture from the cleaning fluid vaporizes and is removed from the system. Vacuum it down for about 30 minutes, this should give you about 28" of vacuum or more inside the A/C system. I have a vacuum gauge "T" connected into the vacuum pump line so that I can accurately watch the vacuuming process. This is a good time to take a soda and sandwich break since it doesn’t go faster if you watch it.
the R134a service fittings on the system: the red goes on the high side and the blue on the low side. This will help others identify that a R134a conversion has been done on the system.
Typical low pressure side R134 coupling
Typical high pressure side R134 coupling
Charging instructions for both R134, Freeze 12 & R12:
Remove the electrical connector from the dryer/receiver and jumper the two connections inside the wiring harness side of the connector together: this allows the compressor to engage in spite of low pressure/no gas in the system. Close both charging gauge valves, and then disconnect the center hose of the charging gauges from the vacuum pump and connect it to the refrigerant can tapper. Put the refrigerant can in the can tapper and screw it down with the can tapper valve closed, then open the valve. Loosen the hose at the center connection of the charging gauge set until the refrigerant squirts out: this purges the line of air and moisture. The refrigerant is added through the low pressure side of the system, so open the low pressure gauge valve to add the refrigerant. Start the car and take note of the idle speed, then set the idle speed up to about 1200-1500 rpm, and turn the A/C on inside and set the fan speed on high. Watch for the pressure on the low side to drop off as you are filling, and the refrigerant can will get warm and stay warm. This tells you the current can is empty and needs to be changed for a fresh one. Before you disconnect the can, be sure to close the valve on the refrigerant can tapper.
Watch the high side pressure on the charging gages and regulate the adding of gas to keep the high side pressure under 350 psi. You will probably need a fan in front of the car to keep the readings below 350 psi. I had to put the refrigerant can in hot water while I was charging the system with it, or else the can got so cold that it quit flowing. Use caution when you do this so that you don’t get water in the charging adapter when you change the cans. When you have added the 2 cans of gas, the high side will read about 250-300 psi and low side about 28-38 psi. Turn the idle speed back to where it was, turn the A/C off, disconnect the charging gauges, and re-install all the caps on the service ports. Remove the jumper from the low pressure switch harness and plug it back on the switch connectors.
R134 only
Then put the R134a Service Sticker on, secure all the loose wiring on the system and you are done.
The typical sticker looks like this, yours may be different.
I hope it cools good, mine doesn’t get quite as cold as it used to driving around town.
The above technical note is for informational purposes only, and the end user is responsible for any damages or injury. The end user bears all responsibility for proper recovery/disposal of any R12 refrigerant.
I have an EPA 609 MVAC certification. And yes, you can shortcut the process, but there are negative factors if you do. Sooner or later, something will cease to function like it should. Shoddy work is a time bomb ticking away, waiting to explode.
gearheadboy
1,425
177
84
Greencastle Pa
Dec 16, 2012
#12
  • Dec 16, 2012
  • #12
:ferry:
Electrical AC relay location on 86?
  • TIGGER
  • Aug 26, 2025
Fox 5.0 Mustang Tech Aug 26, 2025
AeroCoupe
F
AC Compressor Power & Contour Fans
  • Fri Guy
  • Aug 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 15, 2026
BoostedRed89gt
82 Gen 1 Coyote Swap AC Questions...
  • thinkfaster
  • Aug 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2025
thinkfaster
D
Progress Thread Calypso Green 92 LX Hatchback
  • Dakar09
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
rednotch
Electrical 89 fox AC help please
  • Fast89GWILL
  • Dec 5, 2024
Fox 5.0 Mustang Tech Dec 18, 2024
Mindseye007
