Fox body auto trans
  • Thread starter Thread starter SMcD
  • Start date Start date Aug 29, 2008
SMcD
Boston, MA
Aug 29, 2008
  • Aug 29, 2008
Newbie here. I don't really consider my fox a "classic" Mustang, but it seemed to be the only category that fit. Excuse me if its the wrong spot.
I have a 1983 GLX convertible with a carburated 3.8L V-6 and auto trans. Is this a C-3 or a C-4? Whatever, its junk. For short money, I can get a trans from a '93 Mustang 2.3L 4 cylinder. Am I correct in assuming that it is an AOD? Will this bolt up to my V6? Will it work considering that I am carburated and pre-computer (?) Thanks in advance for your help.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Aug 31, 2008
  • Aug 31, 2008
The AOD was most often used behind 5.0 engines; the four and six cylinder engines from the mid '80s to mid '90s were commonly attached to the A4LD. That's about all I know on the '80s non-V8 automatics. You might try the 2.3 Tech or 5.0 tech forums.
havi
29
  • Aug 31, 2008
You'll need a conversion type cable such as one offered by Lokar? to use an AOD behind a carbed 3.8. Fox Tbirds had AOD's behind the 3.8 and 5.0's. I believe the bellpattern is different for the 4 cyl. The newer AOD-E is a better trans and may be worth searching out over the regular AOD. Some 80's vans used a carbed AOD, though are hard to find. A C4 is a good trans, the C5 is not so much. Stay away from any A4LD, IMO. The newer 4R70's are an upgraded AOD-E for the most part with a better gear ratio. I just pulled an AOD from my '88 Tbird, so if you're up my way, you can have it, cheap.
P
PaulS
Greater Puget Sound
Aug 31, 2008
  • Aug 31, 2008
You more than likely have a C3. You can swap in a C4 if you can find an appropriate bell housing. The AOD is going to be a tight fit if you can find one with the right bell housing - Most were used on 5.0 and up.
The C4 can take anything you can throw at it up to about 1000 HP with an appropriate build.
D
D.Hearne
11,730
south louisiana
Aug 31, 2008
  • Aug 31, 2008
Paul, the 3.8 V6(ditto for the 4.2 truck V6) has the same transmission bell pattern as the small blocks.
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
H
Drivetrain 4R70W clutch friction/metals/piston set up questions for transmission guru
  • Hizdudeness
  • Apr 4, 2024
Fox 5.0 Mustang Tech Nov 15, 2024
slow84lx
