Fox body Contour fan conversion, anyone figure out a expansion tank solution to keep factory coolant sensor?
No problem. That's the point of these forums. Share what we know with those seeking information.
I have done a lot things that many would consider unorthodox or would disagree with, but you know what, it all works.
Things like:
- Contour fans run off Contour factory control system and Audi fan controller in lower rad hose
- Lincoln LS brakes all around, re-drilled for 4-lug
- Lincoln LS fuel pump (they are factory rated at 340 LPH)
- '01 Mustang hand brake assembly
- '01 V6 OEM MC and prop valve (no mods to it) with stock Fox brake lines
- trans cooler (I am an AOD car) from an Escape mounted behind GT bumper lower opening
Reactions: General karthief
