no the housings are the same, axle length and bolt hole size changed
Also rear brakes sn95 or newer rear discs. Front brakes are off an 01 bullitt ala 99/01 cobras
Keep in mind of you use fox axles, you'll need special axle brackets from north race cars.
ya but the advantage of getting a diff off a 96 and up is the gear ratio right they come 327 stock? compared to the 273 's..... on the fox and the 94-95.....
Yeah, 2.73 was put into many 86-95 Mustangs, but many got 3.27s. They are certainly NOT rare or even hard to find.ya but the advantage of getting a diff off a 96 and up is the gear ratio right they come 327 stock? compared to the 273 's..... on the fox and the 94-95.....
I'm pretty sure '96-98 all had 3.27's. My rear I got for my car was out of a '96 'Vert and it had 3.27's in it
Good to know. I learn something new everyday3.27s were available. But not the only gear. 2.73s and 3.08s were still available in certain option packages.
http://www.stangnet.com/mustang-forums/threads/gears-on-stock-4-6-2v-98gt-auto-2-73.464980/
99+ is when ford went 3.27 across the board
IMO, always use fox axles, you can add spacers if necessary, if you use sn95 axles only way to take them in is different wheels.
put weight on the backhalf to apply compression.
