  • 1994 - 1995 Specific Tech
Fox MAF
  • Thread starter Thread starter Billy8380
  • Start date Start date Mar 2, 2008
Billy8380
68
  • Mar 2, 2008
Is it possible to use a fox maf on my 94? Read somewhere that their was an adapter plug? where can I buy an adapter
earleys94gt
1,223
Ashley, Ohio
Mar 2, 2008
  • Mar 2, 2008
It should work if the MAF is calc. for 19 lb/hr(stock) injectors.
But why would you want to go from a 70mm MAF to a 55mm MAF?
1.Stock 5.0L 58MM (89-93 Mustangs), 606 CFM
2.Stock 5.0L 70MM (94-95 GT/Cobra Mustangs), 815 CFM
Billy8380
68
  • Mar 2, 2008
forgot to post I was looking at a 73 or 76mm C&L cal'ed for 24# injectors
blksn955.o
3,263
st.louis mo 314
Mar 2, 2008
  • Mar 2, 2008
With the C&L you will re-use your stock MAF electronics. C&L uses a diff. sample tube to fool the eec into thinking another amount of air is coming into the motor.
IMHO the C&L is the worst maf choice for the 94-95 mustang. It will work but you will have the greatest chance/odds of running into drivability issues.
If you want the best deal for running 24's look into running a 94-95 cobra eec. You can run your factory GT maf and direct plug and play with stock drivability. The stock maf is known to be good up to 290-300rwhp.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Mar 2, 2008
  • Mar 2, 2008
The plug will be the same on the Fox MAF. If it already has the electronics in the meter, use those. I believe the transfer function between the Fox and 94-95 MAF is different, so you'll want to keep the same electronics with the housing for the best compatibility. I'm gonna toss this one in tech, too.
Stanger007
2,015
Baton Rouge, LA
Mar 3, 2008
  • Mar 3, 2008
I will be tuning a car this weekend after I install some 24s and a C&L 73mm with the A9L 24# tube.
To my knowledge you cannot install your 70mm electronics into a C&L setup for the 55mm electronics and expect it to work as intended with going into the coputer. The stock transfer between the Fox and SN95 MAF are different by a good amount.
If you can't tune it, you can swap sample tubes with the appropriate one: http://mustangwarehouse.com/Merchan...e=1&Product_Code=CL7324T9495&Category_Code=CL
Wes
blksn955.o
3,263
st.louis mo 314
Mar 3, 2008
  • Mar 3, 2008
He will need to run the correct sample tube for his year and make with the C&L meter. 007 is correct he can not just swap electronics.
Billy8380
68
  • Mar 3, 2008
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
F
SOLD March Ram Air Box and Filter
  • fasterthangas
  • Nov 30, 2025
  • Engine and Power Adder
Engine and Power Adder Jun 2, 2026
fasterthangas
F
For Sale Painless SBF fuel injection harness
  • 74delta
  • Aug 14, 2026
  • Other Classifieds
Other Classifieds Aug 14, 2026
74delta
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
