FOX POWER BRAKES/ FOX PEDALS IN A 69
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
i have a question for anyone who can help....
i know anything is possible but...
is it possible or not worth it to install a fox master cyl and booster on a 69 fastback that had manual brakes (v8 originally a 302 2v)
i am also looking at installing the fox clutch pedal or the enitre pedal assy(which i have) for the clutch quadrant setup for a cable clutch for a tremec 600 to get rid of the sloppy linkage style...
i am also looking to go with RRS front coil overs and 13' cobra brake calipers and rotors....
408 injected stroker as well... if that makes a difference for booster clearance
You'll need to change the pedal to a PB pedal or move the pivot point.
That's not going to happen.
Lots of companies sell cable kits now. I have a Modern Driveline one, Mustang Steve has one, there are a couple of others.
If I was going to that much trouble, for about the same money, I'd get a real front end and buy the Griggs piece, but that's just me.
You should be good to go on that count.
Good luck.
