  • 1994 - 1995 Specific Tech
Fox T5 in SN95 question
  • Thread starter Thread starter Zero_chance
  • Start date Start date Dec 11, 2007
Zero_chance
1,244
Maricopa, AZ
Dec 11, 2007
  • Dec 11, 2007
Can anyone thats done this confirm that a Fox T5 will go in our car if you retain the Fox bellhousing and clutch fork and use a driveshaft spacer?
parchisi
519
New Mexico
Dec 11, 2007
  • Dec 11, 2007
It should work. With my TKO, its got the fox lenth input shaft, using fox bellhousing, and the steeda hardcore spacer. Dont' know if you need the spacer though.
94fordmustanggt
74
Florida
Dec 11, 2007
  • Dec 11, 2007
Just fyi I was told that the only difference between out transmissions were that the SN95's input shafts are 1' longer. I would think the fox bellhousing would fix that. I can also tell you from firsthand experience that a fox t-5 will last about 14 months in our cars It wasn't my fault!
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Dec 11, 2007
  • Dec 11, 2007
You'll need the Fox bellhousing, clutch fork, and possibly a driveshaft spacer to make up the difference in length between the Fox and SN95 transmissions. I believe Steeda sells a spacer.
Zero_chance
1,244
Maricopa, AZ
Dec 12, 2007
  • Dec 12, 2007
Yeah I found the Steeda spacer online. Its just been easier to find a Fox T5 then it has to find an SN95.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Dec 12, 2007
  • Dec 12, 2007
My fox T5 lasted 145,000 miles. The clutch cables a a tad different too. Get a fox clutch cable and clutch fork. The input shaft is 5/8" shorter on the 93 and older T5's
Zero_chance
1,244
Maricopa, AZ
Dec 12, 2007
  • Dec 12, 2007
Good call. I was going to ask that too, about the clutch cable.
defendant420
Pittsgrove Twp. NewJersey
Dec 12, 2007
  • Dec 12, 2007
Don't forget ,it will also move your shifter foward too.
Zero_chance
1,244
Maricopa, AZ
Dec 12, 2007
  • Dec 12, 2007
Thats a good point. Im assuming it wont cause any smashed knuckles on stereo symptoms ????
95Vert
1,785
North Mexico (deep south Texas)
Dec 12, 2007
#10
  • Dec 12, 2007
  • #10
I'm running a fox t5 with fox bellhousing and NO SPACER. You don't need a d/s spacer. What you WILL need is to fab a bracket to set the tranny mount on. The stock location will not reach. A welded piece of metal in the front of the cross member will do the trick. I have no issues with the shifter being further up, still enough clearance for comfortable shifting.
BlownFiveLiter
18
108
Chicagoland
Dec 12, 2007
#11
  • Dec 12, 2007
  • #11
You can possibly get away with using no spacer, but I'd personally want to make up the difference, so the yoke engages the output shaft enough. It may not seem to cause any issues, but the yoke will eventually wobble enough to take out the bushing in the tailshaft, or twist the splines on the output shaft with less surface area being in contact with the splines.
95Vert
1,785
Dec 13, 2007
#12
  • Dec 13, 2007
  • #12
I've had my d/s on there for over 2 years with current visits to the track hitting 1.7x's and haven't had a problem. Maybe I just got lucky.
Zero_chance
1,244
Maricopa, AZ
Dec 13, 2007
#13
  • Dec 13, 2007
  • #13
Thanks for the info about the bracket that needs to be fabbed up. One less surprise when I actually get underway. As far as the spacer goes, Im not going to be doing any track runs but I think Id still feel more comfortable taking up the slack. I can get the spacer cheap enough. What the hell, right?
95Vert
1,785
Dec 13, 2007
#14
  • Dec 13, 2007
  • #14
Right!
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
Taillight upgrade?
  • BeardIsRed
  • Feb 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
