Anyone here have a Fox body hatchback with an after market POWER sunroof / moonroof installed? If so, what brand?
Thanks
Thanks
Shakerhood said:I would NEVER install an Aftermarket Sunroof in ANY Car as I am sure it would leak!
speedytang said:My problem with aftermarket sunroofs(I was in the industry) is finding parts. Lifetime Warranty means nothing if they are no longer in business.
Shakerhood said:Very True, what good is a Warranty with no place to fix it! Plus Factory Sunroofs have drain tubes for water to run out of, Aftermarket ones are just going to have giant sections of Weather Strip.
Mustang5L5 said:The problem with a power sunroof in a Fox is that the roof must retract OVER the roof. There isn't enough room on the roof to slide back into. Half the sunroof would stick out because you have the hinges for the hatch taking up room in the rear of the roof area.
I beleive this is why FOrd went with the pop-out sunroof. Simply nowhere to put the factory roof inside the roof, not to mention the fact that headroom will be significantly reduced.
I love my OEM sunroof. WIth new seals and keeping the 4 drain holes clear with compressed air, it never leaks at all. I love how big and open it is with it off.
SteedaGT9150 said:how do u pop the factory sun roof off?
