FoxBody Conversion for intake.??
FordStang
862
Orange Park, FL
Tried doing a search just got alot of junk. I need to get to the bottom of it. Anyone know what i need to eliminate the EGR Adapter?? All i heard was the Throttle Cable, is that true? How hard is it to Install a foxbody one.
you mean switch over to a fox tb? You mentioned the EGR and TB cables which dont really have anything to do with one another. To switch to a fox TB you'll need the bracket and cables from a fox stang.
When i said EGR adapter i meant The (Elbow). What is different from the foxbody t/b and the 94-95's? Im think prob the way how the cable mounts maybe? Because the elbow peice held our EGR and our throttle cable. Where can i find a nice brand new 65mm FMS t/b for my car?
Pretty easy to do. I got a accufab TB spacer (blank) with the cable bracket flange. I also got a throttle cable and bracket off of ebay, a TPS sensor at a junkyard, and a 5/8 cap at ace hardware for the egr header bung. I also just put a Anderson power pipe for a 86-93 stang on to. It looks pretty cool and most of all it looks really clean looking under the hood.
IAC= Idle Air Control
It's black on 94-95's and that silver tube that bolts to the TB on foxes. I thought I remember you using a 94-95 IAC instead of the fox one when you did your swap. Just wondering if you have any close up pics to see what it looks like compared to the fox IAC.
Jake
Oops, dident think of that. Well I did use the stock IAC valve from 94-95's. Here is the only pic I have. Also a shot of the TB bracket.
