Foxbody Door Hinge Repair Nightmare
Moon Dawg
SoHIo near Cin
I found a great pictorial article on the net for how to repair your door hinge. I tried it out this weekend and the whole project became a nightmare.
I was able to grind off the head of the pin on the top hinge and use a punch to drive the pin out but when I went to cut the hinge pin on the bottom hinge I ran into a snag.
I was using a dremel tool mini cut off wheel and the head of every arbor I had broke (3 of them) after about 10 seconds of use.
I have to find a new approach. What have others done?
So far I tried a hacksaw and an air saw with no results since the pin is hardened.
I found the right tool for the job...
Dremel has a new EZ Lock arbor that uses cut-off wheels with a metal reinforced center. I was able to cut through the lower hinge pin with a single wheel.
I was able to install the new pin easily into the the top hinge but I am having trouble getting the new pin through the bottom of the lower hinge. I tried driving the pin down the hinge the last 1/4 inch using an iron rod and a 4lbs hammer but so far I only succeeded in bending the arm of the lower outer hinge.
Does anyone have any tips on how to proceed?
Does everyone have as much problem as I have had? I have 8hrs into this door hinge repair and I am still not done :(
i bought those same dremel cutoff wheels at lowes, they work great, used one of them on 3 exhaust bolts & still have about 1/4 wheel left, try using the dremel to open up the bottom hole a little
