Foxbody Idle issues
  • Thread starter Thread starter AmericanMuscleEnthusiast
  • Start date Start date Jun 27, 2023
A
  • Jun 27, 2023
I have a 1991 Lx 5.0 with a AOD transmission.
My Idle issues is whenever I start the car it’ll idle fine. Once I start driving and come to a stop the car will stay in an accelerating feeling. The rpm’s are suppose to drop at 800-900 idle, it’ll stay at 1200rpm at a light/stop sign. If I put the car in park the idle will hang at 1200rpm…Once I kill it and restart it’ll idle fine at 800rpm. Sometimes it won’t do this and idle / drive fine. Randomly the car will revv by itself and drive with me on the brakes. I have a newer IAC from oreillys on there now.
Reactions: 4cylredfox89
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,950
5,827
213
Jun 27, 2023
  • Jun 27, 2023
It could be several things. Should pull codes first.
Reactions: General karthief
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Jun 27, 2023
  • Jun 27, 2023
Dump codes. Smoke check for vacuum leaks.
Reactions: 4cylredfox89 and General karthief
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,518
2,941
173
Florida
Jun 28, 2023
  • Jun 28, 2023
Different car ( Merkur ) but I fought this for months in my Merkur.... I actually sold the car as is, and the new owner told me it he found a plugged vacuum line that was the problem..
AeroCoupe
6,182
4,280
183
Claremore, OK
Jun 28, 2023
  • Jun 28, 2023
Surging Idle Checklist - https://stangnet.com/mustang-forums/threads/help-me-create-the-surging-idle-checklist.698148/
"By the term surging idle, I mean an idle that wanders up and down more than 50 RPM, or an idle that starts low and goes high and stays there."
K
Knuckle Dragger
oregon
Aug 8, 2023
  • Aug 8, 2023
my 02 did the same stuff. replaced IAC with the same stores brand. occasionally does it still, yet way better than before. i I think its only going to be completely fixed once its swapped for a Motorcraft IAC to be honest.
Mhalc1
73
21
18
San Jose, CA
Aug 21, 2023
  • Aug 21, 2023
My foxbody did the same thing, rite after I got the motor running. It turned out to be a vacuum leak. As mentioned above, I would check my vacuum hoses and IAC.
Potomus Pete
I'm still waiting for the fully nude shots
5 Year Member
Mar 7, 2019
3,347
1,246
153
Sarasota Florida
Dec 29, 2023
  • Dec 29, 2023
You have to do the checklist. It's a constant process until you find it. Keep checking vaccum lines. Then work on electric connections. You will be happy when its good
KRUISR
1,876
1,014
143
Dec 30, 2023
  • Dec 30, 2023
Agreed, do the checklist and a base idle reset (with IAC and SPOUT disconnected) to set the idle.
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Tuesday at 9:33 AM
rednotch
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
