What color speedo gear do you use? And what transmission T5 Z-Spec?220 with 4.10 gear, proper speedo and runs 11s![]()
I really like the sound of blower whine.![]()
You can't really drive around all the time in vac, though.
Does any of us buy a v8 stang for gas mileage?
I measure smiles per gallon,and I'm banking big numbers.
Dam that's sweet you can put it in 6th gear...for better fuel economy.GT40 Tubular/GT40X/E-cam with 3.73s, T56, & 275/40/17 Michelin Cross Climates
20-22 mpg to and from work (mix if city/hwy)
Hwy: Typically 24-25mpg. 28 mpg best so far. Think it'll go over 30 if I try.
This translates to 250-300 miles/tank when refilling at the 1/8 tank white line.
I have cracked 400 mi on the highway.
And seriously... You don't get that premium exhaust note from good MPGs.
View: https://www.youtube.com/shorts/TzgvFN6vCmE
That sounds like a farm tractor with open headers...lol
This is what I use a z-spec with 4.10 gears .Depending on the version of T56, the 6th gear really isn't that much more than 5th on a 5 speed. The T56 for "aftermarket 5.0" applications has a 0.62 6th gear. The T5 has somewhere around 0.78-0.63 5th gear, depending on the version. I was eyeballing the z-spec one (1352-0251) earlier that has the 0.63 OD.
0.5:1 6th. 0.74 5th in mine.Depending on the version of T56, the 6th gear really isn't that much more than 5th on a 5 speed. The T56 for "aftermarket 5.0" applications has a 0.62 6th gear. The T5 has somewhere around 0.78-0.63 5th gear, depending on the version. I was eyeballing the z-spec one (1352-0251) earlier that has the 0.63 OD.
Maybe not, but I get no fewer smiles out of the 87 octane tune.Does any of us buy a v8 stang for gas mileage?
87 octane tune , do you have a tune for 93 octane?Maybe not, but I get no fewer smiles out of the 87 octane tune.
How much hp lost with 87 octane over running 93 octane?Yeah... Just bumps up timing about 6* on the WOT table, and more gradually throughout the rest of the timing tables. I worried that it would affect my fuel mileage, but I didn't detect anything.
