FPCM go bad from sitting? *UPDATE* not good
My '99 GT has been sitting since late November un started.
Put in a fresh battery and now she cranks but wont start. No fuel at shreader valve. Fuel pump doesnt cycle.
verified that the theft light completes its 3 second "prove out" as well as the CEL "prove out"
Checked FP fuse under hood...ok
Checked for 12v @ IFS switch in trunk....ok
Put 12v power to blk/red wire & ground to brn/pk wire off FPCM to make pump run manually....it does
Checked for voltage at FPCM terms with KOEO and got over 10.5v....this test confirms replacement of FPCM...
Question #1....is my diagnosis correct?
Question #2....why would this happen from the car just sitting? Could a defective battery (shorted cell) cause this failure? This was the reason for the battery replacement today to try and start it.
Thanks in advance!
Thanks in advance!
Gotta grab this guys help when you can!
