- Feb 23, 2004
- 2
- 0
- 0
I had my engine off and hooked up a vac. tester to the kirban fuel pressure regulator, pumped to 10"vac and watched it drop to 0" in 5 seconds. I checked my bypass valve, it holds 10"vac for 5 mins, no problem. Can anyone tell me if the diaphram is suppose to hold a vac or drop? I'm asking this cause I noticed I had airbubbles comming out of the fuel rail when i was checking fuel pressure...you know the clear tube on the gage..I hit the release button and watch airbubbles stream out with gas. I thought there's suppose to be no air in the rails or it should go away....help
