93FIVEOH said:
What did you guys do about the vacuum lines? AFM's write-up is pretty vague. I see how they connected the PCV by tee-ing it off. This is all they say on the subject:
You will need to do a few adaptations to fit all the lines. The most important being the EGR and Fuel regulator vacuum lines.
They didn't further explain how they achieved that. Also, that would be different on my application since I have a fox-body, correct? Also, where would I mount the salt & pepper shakers?
Vacuum is vacuum, connect the lines anyplace they will fit. Cap the unused vacuum ports.
Vacuum line connections:
One large vacuum line from the upper front goes to the carbon canister
One large vacuum line from the rear goes to the vacuum tree.
One small line in the front feeds the Smog pump solenoid control valves on the rear of the passenger side wheel well..
One small line in the rear goes to the fuel pressure regulator.
One small line in the rear goes to the EGR suction regulator.
One large line in the rear goes to the PVC valve.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring
http://www.veryuseful.com/mustang/tech/engine/
The salt & pepper shakers will float between the upper manifold and the EGR spacer with no problems. If you haven broken the plastic clip that mounts them, here's the plan. One end of the top clip fits under the cover plate on top of the upper manifold and the other hooks on the bottom lip of the upper manifold. I believe that Tmoss suggests grinding or filing a small relief for the bottom clip on the upper manifold.
