Friction disk Question!!
  • Thread starter Thread starter Georgie
  • Start date Start date Jan 10, 2007
Georgie
455
Montreal, Canada
Jan 10, 2007
  • Jan 10, 2007
since i broke my tranny Ive been looking for one. I picked up a 4 banger tranny for 150$ cnd. i got the smaller pilot bearing, and I'm going to reuse my old TOB because it had only 2000 miles on it...now ...when i removed my broken tranny, i noticed that the bearing retainer was leaking badly..the seal was busted and got all my clutch full of oil . I feels as tho(for sure) my friction disk saturated oil from the tranny... what should i do? can I use some degreasers? i wiped down the pressure plate+fly wheel wit acetone to remove all grease and oil... but be4 i install everything, id like to know what is the best thing to do for the friction disk! thanx
5.0 Nostalgia
904
CT
Jan 10, 2007
  • Jan 10, 2007
I would junk it and get a new one.
bill302
2,131
alabama,gadsden
Jan 10, 2007
  • Jan 10, 2007
i would seriously get rid of the clutch plate and the weaker 4 cyl. tranny...the 4 cyl tranny has a 240 ft.lb torque rating and the v8 tranny has 300-325 ft lb torque rating depending on the year model...
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Jan 10, 2007
  • Jan 10, 2007
Its junk now as stated above
Georgie
455
Montreal, Canada
Jan 10, 2007
  • Jan 10, 2007
im still gonna use it
bill302
2,131
alabama,gadsden
Jan 10, 2007
  • Jan 10, 2007
good luck!!! i would not use either in my baby.... i hate replacing parts i just installed you will learn...
z2o_what
309
princeton, WV
Jan 10, 2007
  • Jan 10, 2007
i would just replace the clutch disk seeing has how they are only around $30
Georgie
455
Montreal, Canada
Jan 11, 2007
  • Jan 11, 2007
its a McLeod.. i cant just throw it away, i paid like 130 $ for it... plus i realized it was slipping when my old tranny was still working... it ddint slip that much, and i mean its still very drivable... in terms of performance u guys are right, but i wont do any performance driving with a 4banger t5 now would I. lol.. so i guess if i drive easy it should do the job...until i get my Astro Tranny !!!
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Jan 11, 2007
  • Jan 11, 2007
tisk tisk.
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Jan 11, 2007
#10
  • Jan 11, 2007
  • #10
dont use a degreaser because it will soak into the disk and just cause more problems. use brake cleaner and spray it down real good and than blow it off with compressed air. thats really the only chance you have.
speedytang
765
Marengo,Ohio,US
Jan 12, 2007
#11
  • Jan 12, 2007
  • #11
Needs to be trashed but then you can replace it when that 4 cyl T5 goes out in a month. Seems like a waste of time when you can buy a new disc for $40.
9
95GTAODE
200
#12
  • Jan 12, 2007
  • #12
Plenty of people run the 4 pot T5 without issues, including me. Even though it has a lower tq rating, it will last as long as the V8 version provided it's taken care of and you are a good driver.
The T5, in it's various factory forms, was designed with 4 and 6 cylinder engines in mind, not v8's at the power level of STOCK '85-'95 5.0's., let alone modified engines.
In short, whatever will kill a 4cyl. box will kill the v8 version just as quick. Stiff clutches, powershifts, clutch-drops, and WOT shifts into 5th, are a big no-no with any T5.
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
Significant Vibration After Clutch Replacement
  • Ryu
  • Dec 19, 2022
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 20, 2022
revhead347
Should I Get a New Clutch Fork and Pivot Ball Stud?
  • AeroCoupe
  • Dec 18, 2022
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 21, 2022
96pushrod
