Fried Computer maybe?
tonys5.0
122
Jacksonville, FL
I was hooking up my trunk mounted battery lastnight when my hand slipped off the wrench. Some how the wrench got stuck in between the aluminum box and mounting bolt sending sparks everywhere for about 20 seconds (please don't flame me).
I'm lucky the battery didn't explode. Now the car turns over but won't start and I don't hear the fuel pump kick in when I turn on the ignition. I checked all fuses and the fuel shutoff switch in the trunk, and all seems to be ok.
Any suggestions whether the PC might be fried?
-Tony
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if present.
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the black 10 pin connector.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
I went home on my lunch break and pulled the computer out of the car. I have another one from a mass air conversion kit so I hooked it up and still no fuel pump kicking in. Since the pump didn't kick in with the new computer, I'm ruling out the "fried computer" theory.
Now starts the "process of elimination" so I'm going to replace the fuel pump relay under the driver's seat and the inertia switch first to see if that fixes my problem. If it doesn't I will replace the fuel pump since I'm still running the stock one anyway.
Could the sparking of the positive battery terminal cause the fuel pump relay or pump itself to give out? Any other relays I should check?
Today I checked all electrical connections except for the one leading to the pump under the tank, and everything checks out ok.
Tomorrow I should have the new pump relay and if that doesn't do it, then I will know it's either the pump or electrical connector to the pump. If it is the pump then either it was coincidence it should go out right when I arked the battery or it was arking the battery that did it in.
This sucks. I just want to drive!
