Front Coil spring install!
  • Thread starter Thread starter jackchan
  • Start date Start date Mar 20, 2006
1 of 2 Next Last
jackchan
507
Mobile Alabama
Mar 20, 2006
  • Mar 20, 2006
As you may have figured out the front struts, coil springs and brakes is not my strong points on a fox body. There with that said, I am planning on replacing my cut drag race springs with my stock springs because of my front end sitting to low. What is the best way to go about getting the STOCK front coils back in? It seems I remember re-installing these in the past without a coil spring compressor and without much trouble. Last night I removed my "cut springs" and didnt see anyway in hell to reinstall my old stock springs without it being a major pain. Also, has anyone ever installed roller bearings in the control arm pivot points to reduce unsprung friction?
thanks
Ben
Rick 91GT
Mustang Master
95
99
PA
Mar 20, 2006
  • Mar 20, 2006
Spring compressor is by far the safest way.....with out them the spring becomes a missle if it lets loose.
jackchan
507
Mobile Alabama
Mar 20, 2006
  • Mar 20, 2006
thanks
what do you think about the roller bearing idea in the control arm points? would that help weight transfer?
Ben
FORCED2DV8
458
Grand Rapids MI
Mar 20, 2006
  • Mar 20, 2006
It may free up some resistance, but it would creat alot of road noise I would think. You could always try it. If you dont like it switch back.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Mar 20, 2006
  • Mar 20, 2006
X2
V
v8only
2,378
22
49
Mar 21, 2006
  • Mar 21, 2006
leave the strut bolted on, slip the front spring on, put the jack at the back of the control arm closest to the inside of the car, and jack the jack up, guiding the spring/control arm at the same time. you don't need a spring compressor.
for safety's sake you can chain the spring and lock it to the frame.
jackchan
507
Mobile Alabama
Mar 21, 2006
  • Mar 21, 2006
I dont think i can get the spring in with the strut bolted up but I'll try it tomorrow night
Ben
Euphoric306
905
  • Mar 21, 2006
strut bolted up, but the pivot bolts unbolted. easy squeezy japaneezy
jackchan
507
Mobile Alabama
Mar 21, 2006
  • Mar 21, 2006
ahhhh I actually heard of that working, but would that actually be easier or would it be easier to just use the spring compressor?
thanks
Ben
V
v8only
2,378
22
49
Mar 21, 2006
#10
  • Mar 21, 2006
  • #10
if you have access to the correct spring compressor then sure, use that. I did it with lowering springs and no spring compressor. lowering springs makes life a ton easier.
Euphoric306
905
#11
  • Mar 21, 2006
  • #11
some lowering springs... the eibach prokits are taller than the ford racing springs and are a bit tricky at first.
yes, unless you have the correct spring compressor than don't **** around with the other ****, it's pain and doesn't work at all
slvrvert91
#12
  • Mar 21, 2006
  • #12
how much are spring compressors? where do you get them? Any auto store?
gruvee87vertgt
20+ Year Stangneter
Oct 7, 2003
272
26
28
Chicago, Il
Mar 21, 2006
#13
  • Mar 21, 2006
  • #13
listen...I have switched springs on a couple cars now..........I would recommend going to have it done at a shop. they usally charge $100.00
lowering springs are always simple to put on. stock takes so much time and effort. if you have never done it i wouldnt, also get a chain and a lock just incase.
gruvee87vertgt
20+ Year Stangneter
Oct 7, 2003
272
26
28
Chicago, Il
Mar 21, 2006
#14
  • Mar 21, 2006
  • #14
also, MFE and someone else has a writeup around here.
GearHd6
459
Ashford, CT
Mar 21, 2006
#15
  • Mar 21, 2006
  • #15
Best advice ever right there! Dont take chances with a flying spring, it can kill you.
Mavrick
2,264
Collingwood, ON
Mar 21, 2006
#16
  • Mar 21, 2006
  • #16
My C springs with urethane isolators/insulators went in with some muscle. I also recommend using a safety chain or strap, those springs can be dangerous!!
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Mar 22, 2006
#17
  • Mar 22, 2006
  • #17
A tool supply company should be able to provide you with the Correct Ford Style Compressor.
N
niklid05
140
Kutztown PA 19530
Mar 22, 2006
#18
  • Mar 22, 2006
  • #18
craftsman has a sping compressor thing for 40 bucks or so. You need a 13/16 wrench i believe for the nut. took off all of my rear springs with them.
K
ka0tyk
1,610
Los Angeles, CA
Mar 22, 2006
#19
  • Mar 22, 2006
  • #19
im sorry but ive installed both stock and aftermarket springs... eibach, ford c springs, and H&R's on numerous cars. while a spring compressor is needed to get the stockers back IN, its just a waste of time for removing them... wether its stock or aftermarket. i just undo the strut bolts to the spindle, step on teh control arm and get it to its lowest point possible and then pry the spring out of the cup. sure it makes a pop sound but its nothing that would kill you or break any bones... after it pops it just rolls off onto the ground.
you guys crack me up.
jackchan
507
Mobile Alabama
Mar 22, 2006
#20
  • Mar 22, 2006
  • #20
same here kaOtyk.
I've seen articles that show how to remove the rear part of the control arm (front springs) while leaving the strut attached, (i read this article this morning) so I may try that, tonight if it doesnt work then I'll rent a compressor from the local advance autoparts or Oreilys.
the rear springs have never been a problem, non has removing the front springs. The key to removal is letting the jack down easy until the arm reaches it lowest point.
thanks guys for all the replys....I'll tell you the easiest way tonight with pictures!
Ben
1 of 2 Next Last
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
G
Front Sway bar HELP
  • Grabberblueguy77
  • May 28, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 28, 2025
gkomo
