Front Disc Power conversion..what company to go with?
c24sc
114
Hey guys,
Going to do a front disc Power conversion on my 66 V8 mustang. I'm not interested in the granada setup, but have narrowed my choices down to the following. But what I"m really looking for is if anybody has used MPbrakes kit. Also, DFbrakes. They offer really low prices (single piston vs 4) but a lot cheaper. Is it worth buying their 4 wheel setup? And i'm assuming that its not a granada...but not sure.
-SSBC (summit selling it for $12xxUS)
http://www.stainlesssteelbrakes.com/products/detail/444/?make=Ford&model=Mustang&year=1966
-MPbrakes (master power brakes) $949US for power conversion
http://www.mpbrakes.com/products/product-detail.cfm?product_id=301
-DFbrakes $695 for front power disck, and $1180 for 4 wheel power disc.
https://dfbrakes.com/products.asp?id=32
Comments/info welcome.
Thanks
Nate
Check with www.mustangsteve.com
He has a kit that uses 07/08 GT calipers and rotors w/ brackets and hardware.
I'm going to be going with his kit. FYI...you will need larger diameter wheels for Steve's kit. I haven't chosen what exact wheels I'm going to use, but, I don't mind going to 17's.
With his front kit and the crown-vic rear disc I put on mine, I will have right at $800.00 in my 4 wheel disc set-up.
Thanks for responding guys.
Planning on 17s tt2's (7 wide in front and 8 wide in rear). But the reason I don't want to go with the granada kit (or steves) is b/c I"m worried it will chance the track width and therefore push the wheel out closer to the fender. Since I'll be going 17x7 with the standard 4" backspacing, I want it to tuck inside the fender.
I know some guys say that the granada doesn't change the track width or ride height, but some sites say it does, I don't want to take that chance.
Thanks
Nate
I believe that Steve's kit I spoke of doesn't change the track width at all.
email him and verify.. [email protected]
The kit I'm going to get replaces the drum with a rotor. So the only difference in width is going to be the difference in thicknesses of the drum and rotor. Very minimal..I would think 1/8" at best.
K. found some info. The cobra brakes do look great, don't get me wrong. But i've read that they won't clear the curves on the spokes on 17x8 torque thrust 2s. So they are a no go. I read a post on here (somebody was asking if that was true) and I found here as well http://cgi.ebay.com/ebaymotors/Cobra-13-DISC-BRAKE-conversion-65-73-FORD-Mustang_W0QQitemZ110212125215QQcmdZViewItem?hash=item110212125215
Nobody has used MPbrakes?
Nate
That's the pic...upon further research, I see the difference...my bad.
However, the American Racing sight shows what the tt II's will fit the '94 & up Mustangs. For my personal curiosity, I'm to find out if the tt II's will fit the 13" brakes.
granada spindles will not change the track width at all. also www.discbrakeswap.com has 65-66 specific granada spindles, they have the same geometry as a stock 65-66 spindle which is different from stock granada spindles or 67-73 spindles. he had these spindles specifically cast for 65-66 mustangs. i don't think his website shows them but you can send him an email and he'll let you know which ones you need.
any info on those brakes?? I see the cobra sets but nothing on the 05+ brakes
I'm in the middle of this swap. First-hand experience -- TTII wheels won't clear the Cobra calipers on the 13" Cobra Steve setup without a ~1/4" spacer. For what it's worth, I've got 17x7 TTII wheels on the front with 4" BS - the back side of the spokes on the wheels hit the outer face of the caliper (where most of them say "Cobra"). Steve's aware of the problem - you can look it up on the forum on his site.
If such a spindle is really available, this seems like a good option to me. I think it is a very good idea to upgrade to the 70-73 or granada beefier spindle. See the "spindle help" thread in this forum for my reasoning.
I think there may also be an issue with Granada rotors in that I think they "snout" on the bug is larger diameter than stock mustang, which means stock wheels will not fit. If you are planning on getting new wheels this is not an issue.
Chris
Chris
you can have the snout on the hub machined down to fit the earlier style wheels. they won't work with stock steel drum brake wheels no matter what you do to them but they will work with any of the other wheels with the machining
:( So did you go with a 1/4 space then? Or did you have the caliper machine? Not really wanting to use a spacer.
Nate
