Front end Bounce
  • Thread starter Thread starter rsweld
  • Start date Start date Nov 8, 2010
R
rsweld
64
St. Marys, GA.
Nov 8, 2010
  • Nov 8, 2010
I have a 65 Conv. W289 3 speed,my problem is at 45 mph the left front fender bounces up and down (I can see it from the driver seat) and I can feel it in the chassis. I have completely rebuilt the front end, new clutch and pressure plate, drive shaft balanced, NEW front brake drums turned and balanced, all 4 tires balanced several times tried a couple different sets of tires and wheels and the problem persists. It only happens at 45 mph, slower it goes away, faster it goes away. Any ideas? Could an export brace and or a monte carlo bar help to prevent this by stiffening up the front end? I know the front end is out of alignment, could that be the cause? what do you think
Ron
DukeGnarley
597
Auburn/Ellensburg, Wa
Nov 8, 2010
  • Nov 8, 2010
that is weird. is the fender attached to the bumper like it should be? I would get it aligned and see if that fixes it, it's something you should do anyway.
do you feel it more in the unibody or in the steering? It could be deathwobble, which is caused by too much toe in (or too little toe out), and not enough caster. Once deathwobble starts though you usually can't speed up to get rid of it.
R
rsweld
64
St. Marys, GA.
Nov 8, 2010
  • Nov 8, 2010
more in the uni-body, the whole left corner bounces up and down, i had my wife drive beside me to see if one of the front wheels is bouncing and she said neither of the tires appear to be bouncing.
Ron
2+2GT
3,333
10
79
Southeastern Pennsylvania
Nov 8, 2010
  • Nov 8, 2010
Install an export brace and get back to us. You need it anyway. They should have been standard equipment.
horseballz
824
Las Vegas, NV
Nov 8, 2010
  • Nov 8, 2010
Alignment=DEFINITELY, but not to original Ford specs. Se the right specs here and read the article too:
DazeCars, Suspension 101
Also, you didn't mention anything about shocks? If you have not replaced them, it could likely be at the root of your difficulty.
HTH,
Gene
R
rsweld
64
St. Marys, GA.
Nov 8, 2010
  • Nov 8, 2010
I forgot, I just replaced the 2 front shocks 2 wks ago.
Ron
tx65coupe
Nov 9, 2010
  • Nov 9, 2010
I agree. The one peice export brace should have been factory on all Mustangs.
R
rsweld
64
St. Marys, GA.
Nov 9, 2010
  • Nov 9, 2010
I have a 2 piece export brace? 2 short pieces welded to the shock tower and then 2 pieces bolted to them and then they bolt to the front lip of the cowl. The other thing I have that I have never seen before are 2 long round bars going from the export brace mounting points at the cowl all the way forward to the forward most point of the inner fenders. I have never seen these on any 65/66 mustang that I have seen at numerous car shows.
Ron
Az Pete
711
18
49
Panama City, Fl.
Nov 9, 2010
  • Nov 9, 2010
Get the one piece brace and it will replace the multi piece you have from the factory. The round tubes are the factory vert bracing.
iskwezm
4,159
20
79
Rowland Heights,California
Nov 9, 2010
#10
  • Nov 9, 2010
  • #10
are the tires wearing uneven or chopped? When was the last time thery were balanced?
F
Flag Missed
26
Corpus Christi
Nov 9, 2010
#11
  • Nov 9, 2010
  • #11
Have you checked the bolt on the bottom side of the fender a couple inches in front of the door? If it has come off the fender will move in and out and appear to be bouncing at speed. Just something basic to check out. Hope it helps.
R
rsweld
64
St. Marys, GA.
Nov 9, 2010
#12
  • Nov 9, 2010
  • #12
New Tires and I check that bolt it is tight. I can feel the bounce in the whole left fromt corner of the car. the type of bounce you would expect to see with a bad shock, however I just replaced them 2 weeks ago and it didn't help at all.
Ron
P
Pony66
124
#13
  • Nov 10, 2010
  • #13
Ron
Those extra bars are only on convertibles. They have to come off to use the export brace.
2+2GT
3,333
10
79
Nov 10, 2010
#14
  • Nov 10, 2010
  • #14
The two-piece setup is NOT an export brace, it's a flimsy thing sheetmetal item to reduce vibration. They are crap, and should be replaced on ANY Mustang except maybe trailered show cars that are never actually driven anywhere.
By the middle of 65 it was obvious to Ford that the convertible was shaky, so they added those two tubes to late 65 convertibles, and ALL 66 convertibles. Just using the export brace would have been better, but would have cost more. Cheapskates.
Use this:
O
other_shoe
313
#15
  • Nov 10, 2010
  • #15
One other thing on the export brace. If I recall correctly, mustbereal's http://www.stangnet.com/mustang-forums/723029-torsional-rigidity-test-67-coupe.html found that the export brace made one of the biggest differences.
tx65coupe
Nov 10, 2010
#16
  • Nov 10, 2010
  • #16
I know those convertible bars do have to come off to use a monte carlo bar, I don't think thats the case for a one peice export brace.
Wheels-Tires Front end shimmy on 79 foxbody
  • 79fox2245
  • Jul 4, 2025
Fox 5.0 Mustang Tech Jul 7, 2025
General karthief
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
