  • 1994 - 1995 Specific Tech
Front End Help
  • Thread starter Thread starter Brando8912
  • Start date Start date Oct 27, 2010
Brando8912
38
  • Oct 27, 2010
So my steering is terrible and want to tighten it up. I have a 95 GT. I know I have bad tie rod ends because I can hear the tick from moving the steering wheel. What else should I replace while Im down there as preventative?
earleys94gt
1,223
Ashley, Ohio
Oct 27, 2010
  • Oct 27, 2010
Being almost 16 years old...your bushings are probably shot, you can do those too.
Maybe sway bar end-links too.
J
jbond007
  • Oct 27, 2010
You can use a bump steer kit in place of new tie rod ends. They utilyze a heim joint along with a tapered stud that fits into the steering knuckle where your old tie-rods attached. You can also use a bolt through type in place of the tapered stud such as Maximum Motorsports bump-steer kit. This will require that you drill out the taper in the knuckle. I run this type on my car along whith a MM steering shaft. This set-up completely eliminated the slop in my car along with aluminum rack bushings and urethane everything else bushings. Good luck!
H
Aluminum timing chain guides ?
  • healy1963
  • May 5, 2026
2005 - 2014 S-197 Mustang -General/Talk- May 5, 2026
healy1963
H
Wheels-Tires Front end shimmy on 79 foxbody
  • 79fox2245
  • Jul 4, 2025
Fox 5.0 Mustang Tech Jul 7, 2025
General karthief
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
