  • SN95 4.6L Mustang Tech
Front End Popping. Help!
  • Thread starter Thread starter soctty7676
  • Start date Start date Sep 10, 2006
soctty7676
156
  • Sep 10, 2006
Hey all, I need some advice, please bear with this long email and give me any advice you can. I put on new munroe senstrac's all around my car about 8 months ago. Well, about 2 days ago, everytime I apply the brakes or make a turn, there is a popping noise coming from the passenger side suspension. I raised the car up, turn the wheel, no popping sound, put it back down, it pops. And when I say pops, it makes about 8 popping noises turning the wheel all the way to the right. About 3-4 when applying the brakes.
I put my head down there, and it seems to be coming from the shock, so I took off the main nut on the top mount, then zapped it back on tight with an impact wrench....Still pops.
I also checked the ball-joints, the boots are torn, and I need to replace them, but I don't think this is where the popping is coming from. I really think it is the shock.
So, I am going to replace both the shocks and the lower ball joints and have a couple questions. Has anyone else had this problem with the sensatracs? They have a lifetime warranty, so I am going to try to take them back and get new replacement ones.
Also, looks like I am going to have to take off the lower a-arms to take them somewhere to have the ball joints pressed out and in. When I lower the a-arm, how hard is it going to be to take the spring out?
Thanks!
soctty7676
156
  • Sep 10, 2006
I was looking around and found this! http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=38335
Will it allow me to remove and replace the ball-joints without taking the lower a-arm off???? That would be suuweet!
DTNODYA
831
  • Sep 10, 2006
It is probably your tie rod end. Could also be your inner tie rod or ball joints ...
Taking the springs out is easy. Way back in the day when I first lowered my car, I rented a spring compressor and it exploded! So, I just put my foot on the shock as I guide the A-arm down (but don't advise that method ... disclaimer or whatever).... Regardless, it's easy and if you use a spring compressor, good luck.
soctty7676
156
  • Sep 10, 2006
Well, I ordered the part from harbor freight. I will see if it works or not.
I don't think it is the tie rod end. When I turn the wheel, it feels pretty tight and the sound doesn't see to be coming from that. I really think it is the shock, because the sound emits through the sheetmetal in the fenderwell.
I think I will replace the lower ball joints. Try it out, if it makes the noise still, then I will replace the shocks again.
triggz
1,218
Gadsden, AL
Sep 11, 2006
  • Sep 11, 2006
My friends 99 V6 did this exact same thing, but it wasnt the shocks, it had bullitt shocks and h&r springs that are now on his 00 GT and it makes no noises..
More than likely something on the steering rack.
soctty7676
156
  • Sep 11, 2006
The only reason I don't think it has to do with the steering is because it makes the popping noise when I hit the brakes and the front dives. I don't know, I will probably replace parts in this order....lower ball joints, shocks, tie rod ends, steering rack, sell car. Just kidding about the last. I would probably buy a whole new k-member with lower a-arms and coil overs!
Has anyone else with Monroe sensatracs had problems with them?
DTNODYA
831
  • Sep 11, 2006
FWIW, to answer your question about the ball joint tool ... yes, you can replace the ball joints without taking off the A-arm. Use an impact if you have one to turn the clamp.
Also for what it's worth, one time my caliper bolt came loose and was causing a bumping noise when I turned, hit the brakes, strarted driving ... etc. So just check that too .....
soctty7676
156
  • Sep 12, 2006
Thanks for the advice! I checked the caliper bolts last night after the tip. That's the last thing I want flying off!
The noise has turned into more of a creaking sound than popping now. Even makes the sound when I get out of the car.
Anyways, this weekend I am going to change out the lower ball joints, outer tie rod ends, and shocks (see if advance will replace them under warranty). Then get an alignment.
Anything else you guys can think of that I should replace before I pay for an alignment?
Are there inner tie rod ends inside the boots of the rack? If so, should they be replaced? It is a 98 GT with 90,000 miles. The steering feels very tight, no play, just doing the tie rod ends for preventive maintenance.
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Monday at 4:00 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 37 minutes ago
DuluthFoxbody
D
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Front window issues
  • bruno
  • Saturday at 2:16 PM
Fox 5.0 Mustang Tech 25 minutes ago
Dakar09
D
