  • SN95 4.6L Mustang Tech
Front end squeak. Ball joints?
  • Thread starter Thread starter arkansas mystic
  • Start date Start date Jun 21, 2005
A
arkansas mystic
134
Jacksonville, FL
Jun 21, 2005
  • Jun 21, 2005
My front end has started to squeak. It does it when going over a speed bump, and also when you turn the wheels. My best guess is that its the ball joints (car has almost 90,000 miles). Anyone else have this problem? If it is the ball joints, does anyone have the steeda ones? Hows the quality of them and the install?
M
Mstg05
103
Delaware county, pa
Jun 21, 2005
  • Jun 21, 2005
I've had a few of these come into my bay:
Get under there and turn your tie rods/tie rod ends. DO NOT loosten the jam nut, just move them back and forth. If they squeek, keep on moving them back and forth until it stops. Problem with this is that the lack of movement doesn't allow the grease to move around in there. Give it a shot, see what it does.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 21, 2005
  • Jun 21, 2005
Interesting... You may have solved a mystery which has been realling annoying me, the mystery of the annoying SQUEAK!
M
Mstg05
103
Delaware county, pa
Jun 21, 2005
  • Jun 21, 2005
Don't thank me yet, it may not be your problem.
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
P
Suspension Different height ball joints?
  • pindude80
  • Jun 10, 2024
3K
Fox 5.0 Mustang Tech Jun 12, 2024
limp
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
