front hub assembly for 67
  • Thread starter Thread starter pazur
  • Start date Start date Jul 5, 2007
P
pazur
82
northern Virginia
Jul 5, 2007
  • Jul 5, 2007
Does anybody know if there is a hub assembly that fits to front spindle on 67 coupe? I want to do front disk conversion, would like to use separate hubs and rotors instead of early granada rotor/hub assemblies, if possible...
rbohm
6,698
550
204
tucson,az
Jul 5, 2007
  • Jul 5, 2007
sure, the stock rotors for the 67 mustang fits just fine. autokrafters and NPD both carry them.
P
pazur
82
northern Virginia
Jul 5, 2007
  • Jul 5, 2007
But I want just hub without rotor, and then bolt-in rotor coming with the hub, same as done for rear disk brakes swaps. I have just found separate hubs and rotors in 94 gt, but don't know if spindle diameters are same. The reason - just don't want to replace hub every time when rotors are needed to replace.
rbohm
6,698
550
204
tucson,az
Jul 5, 2007
  • Jul 5, 2007
the 65-67 brake rotors are a two piece set, hub and rotor separate. you however have to get the pair together. you can only get drum brake hubs separately.
www.autokrafters.com
part number GD7173
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 6, 2007
  • Jul 6, 2007
You can use a drum brake hub and mount a late model disc to it. This is how some of the late model disc brake conversions are done along with a custom bracket to locate the caliper properly.
joesgt281
163
Katy, TX
Jul 6, 2007
  • Jul 6, 2007
as Rusty said....check out www.mustangsteve.com.
his system uses SN95 Cobra calipers/rotors. it requires the use of drum spindles/hubs, which allows you to use the Cobra rotors which are replaceable.
I went this way over some of the others because I wanted the big 13" Cobra brakes. It does, however, require the use of 17" or bigger wheels.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 6, 2007
  • Jul 6, 2007
Since he is using 67 spindles they are the same for drum/disc. He will only need the pair of new hubs.
Travis77
153
Baytown, TX
Jul 6, 2007
  • Jul 6, 2007
I believe the majority of folks are using the 1970 spindle since they are beefier. Although not installed yet, this is what I went with.
joesgt281
163
Katy, TX
Jul 6, 2007
  • Jul 6, 2007
Travis,
I haven't sourced my spindle/hub yet.
Does the same hold true for 70 spindles as Rusty said for 67's (you can use either drum or disk spindles)?
I currently have stock 70 disks (and spindles) in the front but was thinking I couldn't use them, that I would have to go with drum spindles.
Do you know if the 70 disk spindles will work with the drum hubs?
Joe
P
pazur
82
northern Virginia
Jul 6, 2007
#10
  • Jul 6, 2007
  • #10
Thanks everybody for advice, I did not know 67s have separate hubs... if they have that's different story and going with 13". About the kit for 94-95 cobra swap, looks great but I would not mind steel brackets and priced way lower than $350 for two brackets (??)
Travis77
153
Baytown, TX
Jul 6, 2007
#11
  • Jul 6, 2007
  • #11
You can use 67 drum/disc spindles on the conversion mentioned earlier. Also you can use 68-73 drum spindles. The aftermarket brake companies use this style because it makes for an easier braket in which they fabricate. But to aswer you question JoesGT281, I'm not sure. I believe you can, but I would definately post over at mustangsteve's forum to get specifics. Sorry
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 7, 2007
#12
  • Jul 7, 2007
  • #12
joesgt281 said:
Travis,
Joe
65-67 spindles are the same for drum and disc. There is NO difference in the spindle. From 68 and up they are different.
joesgt281
163
Katy, TX
Jul 7, 2007
#13
  • Jul 7, 2007
  • #13
Thanks for the clarification.
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
Brakes Brake caliper ID help
  • kidott
  • Sep 2, 2025
Fox 5.0 Mustang Tech Sep 2, 2025
AeroCoupe
Rear ends? And I don't mean the pretty kind.
  • WORTH
  • Jun 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 14, 2025
limp
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Sn95 new style hub retaining nuts
  • limp
  • Mar 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 7, 2025
limp
