  • 1994 - 1995 Specific Tech
front shocks problem
  • Thread starter Thread starter Engel
  • Start date Start date Jun 19, 2008
Engel
219
Currently Fort Walton Beach
Jun 19, 2008
  • Jun 19, 2008
A few months ago I switched out some leaking saleen bilstein shocks with some bilstein hd's..
after the bilstein hd's were installed, there is a loud THUD whenever I go over even the smallest speedbump..
Is it possible they may have shipped me the struts with a shorter travel??
WHITE94COBRA
816
HUNTINGTON BEACH
Jun 19, 2008
  • Jun 19, 2008
Just out of curiosity why didnt you send the bilsteins back to bilstein to get rebuild? You know they carry a lifetime warranty right? I also have the Saleen ones and I have sent them back without a hitch.
Now your question, Bilstein has an internal bump stop, so even if it was bottoming or topping out it would not make a thud. If you have CC plates some have complained of a loud sound from them with the bilsteins.
spock2001us
143
  • Jun 19, 2008
When I did my front suspension, there are about a dozen bushings on each side plus a couple of bushings holding the sway bar, and of course in the strut tower. I had thuds too until I starting replacing bushings. I think the thud for mine was the two worn bushings that hold the sway bar to the chassis which let the bar bump up and down. Assuming everything is tight, I would look at bushings. I read that warn ball joints can cause a thud too.
HISSIN50
34
129
Jun 19, 2008
  • Jun 19, 2008
As noted, a loose top-strut attachment can cause thunking.
Loose end links are also a common cause.
Engel
219
Jun 19, 2008
  • Jun 19, 2008
i wanted the more cushy ride of the hd as opposed to the saleen n2 shocks :/ I had hd already in the rear
ill check the sway bar and shocks.. right now the shop has my car hostage for clutch swap
GTA_V6_Mustang
1,326
Miami, FL
Jun 20, 2008
  • Jun 20, 2008
so you should send your old ones in for repair and give them to me
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
