Front skinnies backspacing question.
Teddyd
MA
Hi, I want to order the inexpensive vision wheels (prostar knockoffs) and the smallest they make for skinnies is 4” with 1.75” as the only backspacing available.can someone please tell me if this will work on my 1985 stock suspension foxbody? I’m sorry if this had been gone over a million times but I’ve been searching and searching and all I see is Info about 3.5 inch front wheels.
thank you
Reactions: 2Blue2
  • Sponsors(?)
96pushrod
Mustang Master
May 15, 2018
878
533
103
28
Savannah
I had a set of wheels with the same dimensions on a car with the pbr brakes and they needed a thin spacer to not drag on the caliper. Idk about with stock brakes.
revhead347
Just rub Vaseline all over
8,469
1,254
214
40
Acworth, GA
I don't think it's going to be the same with stock 1985 brakes. I would say the backspacing doesn't really matter, it's almost always right about centerline on skinny wheels, which is what 1.75" on a 4" wheel. Doesn't matter what wheel you get, you might need a spacer.
Kurt
2Blue2
will be trying this sex one when I can find it
Mar 5, 2019
2,409
1,452
133
53
Oahu
Yes! Pics!!
revhead347
8,469
1,254
214
40
Acworth, GA
I probably should have elaborated. The backspacing isn't going to change the need for a spacer, since it's the caliper that generally rubs on the inner face of the wheel, not the inner diameter of he wheel.
Kurt
