front spring suggestions
331 stang91
261
wisconsin
So I need some new front struts. I'm going to go with 90/10. I'm looking to also replace the springs. What would be a good match with the 91/10 struts. Keep in mind this is a go strait car wit skinnies on the front so I'm looking for the front of the car to get up better then it does. There are lakewood drag struts on there noew but there leaking. Also I mostly drive on the street, but it only really goes out on the weekend. I don't mind having to take it easy over bumps but I don't want to go to crazy with it. Thanks !! Also looking to keep stock height since I am not changing out the rears yet.
4 banger springs would work well especailly if you can find them cheap. The Moroso's are great if you can wrestle them in place. I had a set on mine but swapped to coil-overs.
