Front Springs
FordGuy88
241
Park Ridge, IL
I have a 88 mustang 5.0 I am tring to put drag launch springs in the front right now and it just wont work. I tried to compress the springs and stuff and it just wont work. Is there any thing I should know about them? Does any one have any tips?
Thanks alot,
Dave
What method are you using for compressing the springs? Note the kind of compressor you are using (internal, external, clamshell, etc).
Good luck.
We ended up attaching the strut back to the control arm and taking the control arm loose at the k-member to give a better angle. We had to compress the crap out of it to get it to go. Also are you using the spring compressor that goes up through the center of the control arm and spring? Good luck.
Dave, is the rod through the middle of the compressor hitting the upper perch before it compresses the spring enough?
When that happened to me, I made a shim to put under the head of the middle shank on the compressor. The shim shifts the shank lower so you can compress the spring further before the shank hits the perch.
Good luck.
