front struts how tight?
  • Thread starter Thread starter rmsample
  • Start date Start date Apr 10, 2007
R
rmsample
  • Apr 10, 2007
how much should i tighten the strut mount retainer nut? (the big one in the center top of the strut)
LASTFOX
105
RI
Apr 10, 2007
  • Apr 10, 2007
I just hit it with an air gun while jacked up to get the nut started and then lower the car to the ground and sock it tight.
stang&2Birds
2,091
New England. :-) CT/MA
Apr 10, 2007
  • Apr 10, 2007
Yup, that's pretty much the way it has to be done.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Apr 11, 2007
  • Apr 11, 2007
Yep, I had to hit it with the Impact Gun too. I want to say the Correct Torque was 57 Ft. Lbs., but its next to impossible to keep the Strut Shaft from Spinning, so the Impact Gun worked perfect.
HISSIN50
34
129
Apr 11, 2007
  • Apr 11, 2007
I don't have a lot of 'feel' with impact guns so I did it by hand. If you have a small pry bar, you can put it in the slot in the top of the strut shaft. But lay the tip of the prybar across the slot from the side (so the prybar is perpendicular to the shaft, not from the top like you would use a screwdriver). With the prybar sideways, you have leverage. Now you can cinch the top nut up.
Just another way to do it if you dont have an impact gun.
Good luck.
Suspension UPR Coilover sleeve dosent drop down over strut
  • Creomod
  • May 25, 2025
Fox 5.0 Mustang Tech May 28, 2025
RaggedGT
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
Suspension Shock install ?
  • DemonGT
  • Feb 10, 2025
Fox 5.0 Mustang Tech Feb 10, 2025
91AOD5.0LX
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
