Front Suspension parts
Hef5.0weisen
Mar 5, 2004
574
NorthWest Florida
After putting on the Ford "C" springs, I'm noticing some nasty uneven tire wear, inner edge is about gone. No problem, gonna order up some new tires, but wanna do it right this time, prevent the uneven wear. Shopping list includes MM cc plates, new ball joints and tie rod ends, then off to alignment place. Wondering if the Steeda X2c ball joints (vs. stock replacments) is worth it, or neccessary?...and will any run of the mill garden variety alignmnet joint be able to do an alignment with aftermarket parts?
Thanks,
Brian
(struts/shocks and springs are fresh)
With C springs you don't need the Steeda X2 ball joints (FRPP has these same ball joints too). You can get more drop with them using some spacers included with the ball joints. As for the CC plates there should be instructions on where to set the alignment. My FRPP CCs did and the alignment shop had no trouble aligning my car's front end.
