I think the one Tie Rod End is bad on my 2000 GT. The passengers side is very loose and will turn very freely. The other side is stiff and is hard to turn! I was just wondering if anyone can confirm this! Thanx
the jam nut is loose. they should not turn freely. why were you turning them?? take a 21mm wrench and tighten them down and then go get it aligned b/c if they are spinning taht means the toe is out!
well when i do alignments i grab the tire in the 3 and 9 o'clock position and move it back and forth there should'nt be any movement if there is then either the inner tierod went bad and sometimes it is the outer tierod
