I think I finally got the timing chain installed correctly (the thrust washer problem) if you have been following my other problems...
Well anyways...when I go to put on the timing cover...it keeps moving the gasket away from the oil pan bolt holes...I've tried it by myself and with a friend and we can't get the gasket hole to stay over the bolt hole...make sense?...it keeps getting blocked...
Does anybody have tips to keep that gasket there...it keeps distorting and the rubber gasket goes over the hole...I tried probably a dozen times...
Thanks,
David
Thanks,
David
