frustrated with fuel lines
  • Thread starter Thread starter Nicoleb3x3
  • Start date Start date May 9, 2007
Nicoleb3x3
274
southern NH
May 9, 2007
  • May 9, 2007
ok, so my rubber lines connecting stainless hard lines on the car to the hard lines on the engine have gotten destroyed by my tire (last year). It was clamped back over the hard line end...and it's not acceptable fix since I've already had it leak once.
....so....
I plan to have the tube cut and flared to an AN 06 fitting - easy right?
well, no; because the rails at the base of the engine are ford male connectors....and I bought a russel line that only fits the female end on the fuel rail.
so.....I could eliminate the mid/side rail going up the side of the engine (since no one makes a ford female, only the male version is available believe it or not) so..I can run the braided fuel line up from the bottom to the fuel rail itself eliminating the need to use female ford connectors.
so now I need to get braided line longer than the one I have.
but the only ones I want are the jegs 350 hose, but I would need to assemble the hose ends myself...has anyone assembled these fuel hose lines/fittings before? some are twist on...but I think these require crimping??? I wanted to run the back braided line from the top of my engine (so yeah I'm being picky since I have so much time invested it might as well be what I want)
the line is here
http://www.jegs.com/webapp/wcs/stor...761335_-1_10019
the connectors are here
http://www.jegs.com/webapp/wcs/stor...762963_-1_10019
Nicoleb3x3
274
southern NH
May 9, 2007
  • May 9, 2007
ok, so my dad will help me attached the hose ends (he's done this before)
so here's another question, is there any problem eliminating the side fuel rail comming up the side of the engine? isn't there some thing on there, shrader valve or something? do I need a shrader valve? what does that do?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 9, 2007
  • May 9, 2007
The schrader valve is the pickup place for a fuel pressure test gauge.
Any place that can fabricate hydraulic hose assemblies can make the braided stainless steel hose assemblies.
See http://www.aeroquip.com/pages/performance.html for more information on High performance automotive hose products
AN fittings require a 37 degree flaring tool. A standard automotive or household plumbing tool is 45 degrees and cannot be used with AN flare fittings.
See http://www.mscdirect.com/ , http://www.mcmaster.com/ or for the flaring tool you will need . Prices start at $75 and go up
http://www1.mscdirect.com/CGI/N2DRVSH?PACACHE=000000013509163
http://www.mcmaster.com/ctlg/DisplCtlgPage.aspx?ReqTyp=CATALOG&CtlgPgNbr=2252&term=Flaring
Sponsored New J&M Release: 2024+ S650 MagneRide Front Brake Lines
  • MRaburn
  • Mar 6, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Mar 6, 2026
MRaburn
D
After Market fuel rails with Stock fuel lines
  • dropteeth
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
2000xp8
Sponsored New Release: 2024+ S650 Brembo Rear Stainless Steel Braided Brake Lines
  • MRaburn
  • Mar 6, 2026
MRaburn
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Sponsored New J&M Release: 2024+ S650 Full Front + Rear Stainless Steel Braided Brake Lines
  • MRaburn
  • Mar 6, 2026
MRaburn
