Fuel Cell Install Help!
1984notch
I bought a 16 gal rci fuel cell, I didn't realize I would have to cut some of my spare tire hole, but I did, now will I just be able to make these cuts in the corner to get my cell to fit and cut for the sump and be good? Good as in passing tech if I wanna go to th track? Or will I fail? Here's. A pic of what I cut out of the spare tire well, I did this on each side where the space got smaller the closer to the bumper it got.
Long story short, you can cut whatever you need to in the trunk area. The biggest thing that you will want to ensure is that the tank is properly grounded from the filler neck, is properly fastened, has a roll over vent and is isolated from the drivers compartment via a metal firewall. For a coupe this means installing a metal panel behind the rear seat and in the package tray. End of the day you need to feel safe in the car, I've seen a ton of questionable things pass the "tech" at the track.
Alright, basically I notched the corners, and was gunna cut out the hole for the sump, and I'm keeping the rear seats so wouldn't those be my bulkhead in the coupe? And don't you ground it with a wire on the chassis? And then the dump tube I believe it's called to vent gases?
Lets think worst case scenario... the foam and fabric seats are hardly fire resistant. You will need a steel or aluminum fire wall behind them and again above them on the package tray to be safe. If you don't feel that it's needed than that is your prerogative, roll the dice and see if it slips by the track. Plastic fuel cells are know to have started fires from static electricity hence the grounding of the metal upper fuel neck ring to a good chassis ground, the metal straps that hold the tank in do not suffice as a good ground. The tank needs to be vented but make sure that you have a roll over valve installed on the line, most tanks have them pre installed but it's worth double checking
Reactions: FoxMustangLvr
I gotcha, now if I bought the Scott rod spare tire hol cover and mounted the cell in that would I need to build a cover around the sump still if the sump doesn't hang lower than the bumper?
It's not a matter of covering the sump, fwiw my car is completely open on the underside of the cell as most of the back half of the car was removed. So long as the drivers compartment is isolated from the battery and fuel cell there is no issue. For that matter, in a coupe that uses a firewall (since you have a cell) you do not need a battery enclosure either.
