Lots of today's vehicular wonders display read-outs telling the mpg, or fuel being consumed, at any moment. My question is are the sensors used to power these displays generally-available? Could a guy rig one in his fuel line and view fuel flow rate continuously, as he drives along?
Second thought: Realization that one's car is using too much fuel, more than usual, can't account for a reason, beyond the operating reasons, injectors, plugs, pedal-foot fell asleep, etc., what about fuel leaks?
My wife says she smells gasoline. I'm getting really horse
gas mileage. Connection?
Throw a fuel pressure gauge on the Schrader valve, turn key on and off a few times, observe gauge. Pressure drops steadily? Fuel pressure regulator leaking internally, bleeding pressure away to tank. OR, leaking externally, the source for the gas odor.
How about leaks in the fuel line delivery system? At filter, observed pressure would drop as described above when key turned off. But, in RETURN LINE, which is isolated from feed line by a nice spring-loaded valve in the regulator, a leak anywhere is undetectable by the pressure-drop check. You could be driving along losing fuel via a return line leak, it simply vaporizes (if, hopefully it does not catch fire), and is gone. You've already paid for it in mpg lost.
Just sayin' that a fuel leak causes low mpg. If in pump to eng. feed line, detectable by gauge. If in Eng. to tank return line, NOT DETECTABLE except by nose or maybe fire.
Check it out. Just sayin'. imp
gas mileage. Connection?Throw a fuel pressure gauge on the Schrader valve, turn key on and off a few times, observe gauge. Pressure drops steadily? Fuel pressure regulator leaking internally, bleeding pressure away to tank. OR, leaking externally, the source for the gas odor.
imp
